Question about NAD T762 Receiver
NAD T762 stuck in standby
Product was switched off, de-connected completely, moved and then reconnected. From working perfectly well, it now will not start up. It powers up in standby mode with yellow LED (correct), but then it will not repond to th remote or a button press. Is there a master reset? Can anyone help ?
Thanks
René Cason
Posted by renec on
Tariq Waheed
    New Friend:
    Problem Solver:
  • 8 Answers
Remove the power plug first, try to find the Battery inside the unit,Remove it, just for a minute, or two, and put it Back, hope it work again.if you don,t find in the users manual ,how to reset !
Posted on Oct 17, 2017
1 Related Answer
Anonymous
SOURCE: NAD T762 - no sound
Try reseating the prologic/output board. Second one from the right (from the front of the reciever), that fixed my no sound problems on many channels. You will have to take out a few screws to remove and reseat it, and while you are at it clean the connections.
Posted on Feb 03, 2008
Error Oxc18a0206 Fallo de sistema de tinta. No se
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 12, 2011 | HP Photosmart C6180 All-In-One InkJet...
Buenas cordial saludo alas personas que puedan leer este mensaje. y ante mano les deseo una feliz navidad y un lindo prospero año nuevo lleno de muchas bendicciones. el motivo de este...
  5. Wait 60 seconds.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | HP Officejet 5610 All-In-One InkJet...
Me marca fallo en el sistema de tinta. No se puede copiar. Consulte doc. de impresora. Error Oxc8a0001
  5. Wait 60 seconds.
Nov 02, 2010 | HP Photosmart C6280 Printer
States scanner failer; turn off ;then on; have
Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the product control panel. While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible. CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
  • If the scanner mechanism moves across the scan bed, but the light is not lit, proceed to Solution six: Service the product .
  • If the light is lit, proceed to the next solution.
Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
  1. Make sure that the part number on the power supply matches the part number listed in the User Guide .
  2. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the copy job is successful, you do not need to continue troubleshooting.
      NOTE: Power strips and surge suppressors can sometimes prevent enough voltage from reaching the product.
  4. If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
  5. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the error message displays again, proceed to the next solution.
Solution four: Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Solution five: Reset the productFollow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
Solution six: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 26, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Error 0xc18a0206 de hp d7100
Reset the product:
  5. Wait 60 seconds.
Mar 30, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printer not printing
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear access door. Press in the tab on the left of the door, and then pull out the door. Figure 1: Remove the rear access door c00861145.jpg
  3. Gently pull the paper out of the rollers. If printing labels, make sure that a label did not detach from the label sheet while passing through the printer.
  4. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water.
  5. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the paper rollers c00246512.jpg
  6. Allow the rollers to dry completely.
  7. Replace the rear access door. Align the pegs on the right side of the door, and then push the door forward until it snaps into place. Figure 3: Replace the rear access door c00861146.jpg
  8. Reconnect the power cord to the back of the product.
  9. Press the Power button (c01345237.gif ) to turn on the product.
  10. Load paper in the paper tray.
  11. Try the print job again.
  12. With the product turned on, open the product cover. The carriage might move to the center of the product. Allow it to move to that position.
    1. c01553685.gif 1 - Print carriage
    2. Without turning off the product, disconnect the power cord from the back of the product. CAUTION: In the following steps, you move parts by hand. If you do not unplug the power cord, there is a risk of an electrical shock.
    3. Disconnect the power cord from the wall outlet.
    4. Make sure the print cartridges are secure, locked into the carriage, and have not come loose.
    5. Check for any obstructions under or around the carriage that are preventing it from moving.
    6. Make sure the carriage can move freely across the width of the product by firmly pushing the carriage to the left, and then to the right. Clear any obstructions.
    7. Close the product cover.
    9. Reconnect the power cord to the wall outlet.
    10. Press the Power button (c01345237.gif ) to turn on the product.
Jan 11, 2009 | Office Equipment & Supplies
Carriage jam
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Nov 11, 2008 | HP Photosmart C4280 Aio Printer
Psc 2110 carriage jam
Nov 02, 2008 | HP PSC 2110 Color Printer
VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Jan 18, 2008 | Vtech 9009111 Cordless Phone
NAD T762 Receiver Logo
Top NAD Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
jdthefixer
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
