Question about Cambridge Soundworks ton Theater T300 Home Theater Speaker System, Mahogany System
That is the standby mode but if its not kicking out of standby mode it could be a fuse issue The T300 uses a 2.5A fuse. To replace the fuse: 1. Unplug the AC cord from the AC power source, then remove the AC power cord from the speaker's power connector. 2. Remove the fuse cap with a small, flat blade screwdriver (see diagram 2). 3. Remove the fuse from the fuse cap (see diagram 3). 4. Replace the fuse inside fuse cap with another metric 5X20mm size fuse 5. Replace the fuse inside the cap, replace the fuse and cap in the power connector (see diagram 5). 6. Connect the AC power cord to the speaker and raise it upright.
7. Connect the power cord to an AC power outlet
Posted on Jun 01, 2011
that is out of the manual if you do not have the manual any more then click the following link below.
http://download.cambridgesoundworks.com/...
ok so it didn't hyperlink it you will have to copy and paste the link
