I would ad an additional column where there is a 1 if the check mark is in the relevan column in he same row then add those. Ie if a1 is a check mark then b1=1 then add colum b
To create an option button in Microsoft Office Excel 2007, make sure that you add Option Button (form control) to the Quick Access Toolbar. To do this, follow these steps:
Click the Microsoft Office Button, and then click Excel Options.
Click the Customize category, select All Commands in the Choose commands from list, select Option Button (form control), and then click OK.
To create an option button and to assign a macro to it, follow these steps:
In Excel 2003 and in earlier versions of Excel, click Option Button on the Forms toolbar, and then draw the outline of the button on the sheet.
In Excel 2007, click Option Button (form control) on the Quick Access Toolbar, and then draw the outline of the button on the sheet.
Select any cell in the worksheet.
In versions of Excel that are for Microsoft Windows, right-click the option button, and then click Assign Macro.
In versions of Excel that are for Macintosh, press COMMAND while you click or press CTRL while you click, depending on your operating system version. Then, click Assign Macro.
In the Assign Macro dialog box, click the name of the macro that you want to assign to the option button, and then click OK.
When you click the option button, the macro will run.
www.autozone.com create a account log on to that account add your car to it. and you will be able to view the repair manual for it for free hope this helps.
Click the Microsoft Office Button , click Excel Options, and then click Add-Ins.
View the add-ins and application extensions that are categorized as follows:
Active Application Add-ins Lists the extensions that are registered and currently running in your Office program.
Inactive Application Add-ins Lists the add-ins that are present on your computer but are not currently loaded. For example, smart tags or XML Schemas are active only when the document that references them is open. Another example is the COM add-ins that are listed in the COM Add-ins dialog box. If the check box for a COM add-in is selected, the add-in is active. If the check box for a COM add-in is cleared, the add-in is inactive. To learn how to open the COM Add-in dialog box, see the section called Turn off or manage the installed add-ins.
Document Related Add-ins Lists template files that are referenced by currently open documents.
Disabled Application Add-ins Lists add-ins that were automatically disabled because they are causing Office programs to crash.
I would suggest to protect the sheet first off all. Make sure you write your password down so you won't lose it. Second, try to sort your data A-->Z it'll make your job much easier.
spammer
