Question about Kenmore 98702 Stacked Washer/Dryer
My washing machine door was forced open while the cycle was puased/stopped. Now the machine will not work, it only blinks alot when i try to start it. I don't have the owner's manual, can you help me? Its a Kenmore Model 417 front load stacked washer/dryer
Posted by cameronsjr on
Anonymous
    New Friend:
  • 171 Answers
If you forced it open, you probably broke the lid safety switch. depending on how technical you are, might be time to call in the repairman.
Posted on Jun 01, 2011
My whirpool locked light keeps flashing and wont wash
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Daniel
1helpful
Hi my washing machine door wont open, feels like the lock has broke ??
hi have you tried turning machine off at plug for a min then power back on put on a cycle press start. wait till it starts to fill and press stop and hold down the reset button till it beeps and wait till door unlocks. Or a quick way to open the door is unclip the foot kick stopper at bottom front of machine and pull the emergency door open which is a thing peace of hanging plastic. if none of this works try starting a cycle then press stop soon as it starts to fill and turn off on machine not at plug. hope this helps.
1helpful
Blinking red lights and no washer operation
Dave, glad I could help, I'll mark this one as solved.
Dead in the water
End of cycle? After the end of cycle you have to wait for 2 minutes minimum (or hear a click), only then you have to try the door; or your door won't open & if you force it you'll damage the door mechanism (not good). End of cycle means "your wash is done".
Pl rate if helped.
18helpful
2answers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Door locking is flashing so it wont start a cycle
Try pressing "end of cycle" button; wait a couple of minutes to open your door, do not force. Then shut door to restart your new cycle..........
Rate me pl. if helped. If not click 'thanks for trying', this prob will come up for others to solve.
40C cycle stopped with 12 mins on display - now nothing works
Press "end of cycle" & wait for 2 minutes then try the door, do not force the door........................ If problem persists go to your model above & click on your model number & look for solutions....should find something.
Blinking Cycle Light
Most likely a faulty door interlock switch...try closing the door with more force, or pressing the door while trying to start...if this works it may be time to find a door lock in the meantime... Oshie
Door jammed
take the top off the machine,put your hand down to the reigon of the door lock and by using a small screw driver the catch on the door can be forced open without doing any damage.
Kenmore 98702 Stacked Washer/Dryer Logo
Michael Thomas
Michael Thomas
Paul Carew
Vernon Taylor
