Question about 3Com NBX 3102 IP Phone
I'm trying to connect a 3com 3102 3c10402b ip phone as a sip phone in an avaya cm 5.2 ses, will it work?
Posted by gil_pulido on
5 Related Answers
Anonymous
  • 9 Answers
SOURCE: Cisco 7960G IP Phone Problem
Try to manually reset the phone - **#"Settings" (this will unlock the configuration) + Network + menu under number "33" - erase the configuration. Then the phone configuration will be erased. Also you can manually set IP address and TFTP server
Posted on Jun 10, 2008
Anonymous
SOURCE: Avaya 5610 IP Phone
Press mute reset (mute 73738)
Posted on Oct 21, 2008
Anonymous
SOURCE: How to configure Avaya's IP Phone 5610?
What IP did you give the phone? When it says discover, its looking for the call server, which it is not finding.
Which system is this on? If IP office, you may need to build an IP route in the system for that subnet.
Posted on Feb 15, 2009
Anonymous
  • 10 Answers
SOURCE: Using AVAYA 4610SW IP phone
Answer to the second problem :-
1. The changes in the ring tone has to be made by accessing the Avaya server where the phones are registered.
2. Log in to the avaya server...... enter change station <station number> on the command prompt
3. In the personalized ring pattern field, you can select one out of the 8 available options by typing any digit between from 1 to 8.
4. The ring pattern of that particular station will change accordingly.
5. Keep the personalized ring pattern of all the stations different by assigning different digits against this value
Posted on Apr 02, 2009
Bery Silvoza
  • 7 Answers
SOURCE: Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Find detailed configuration guide on how to setup Cisco UCM with Ozeki VoIP SIP SDK at: http://www.voip-sip-sdk.com/p_42-how-to-setup-ozeki-voip-sip-sdk-with-cisco-unified-communications-manager-voip.html or with 3CX at: http://www.voip-sip-sdk.com/p_124-voip-sip-sdk-3cx-voip.html
Posted on Jan 27, 2012
What is 3x phone
For 3Com that would mean a 3100 series or 3500 series phones. The 3100 series phones are for NBX and VCX phone systems and the 3500 series phones are for VCX only. Both are also SIP compliant.
Apr 16, 2014 | 3Com Computers & Internet
3COM 3100 entry phone, how to configure SIP
From Digium Mailing List:
3Com 3100 series phones do not support SIP with non-3Com systems. They have a basic boot loader which must download code from a 3Com NBX or a 3Com VCX system. If you don't have either of these, then you won't get runtime code on the phone, thereby making it impossible to use the thing with Asterisk.
Asterisk Users 3Com Phones
Mar 14, 2014 | 3Com Computers & Internet
Nbx 2101
You can't. The 1100 and 2100 series 3Com phones aren't SIP phones. Only the 3100 series phones can be used.
May 28, 2012 | 3Com NBX 2102PE IP Phone
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
Are NBX entry Phone Sip compatible?
The 2100 series and older aren't SIP compatible. The 3100 series are.
Oct 19, 2009 | 3Com NBX 2102 IP Phone
We have a mitel 3300 connected to cisco CM thru siptrunk
can somebody help me we have a Sip connection between a mitel 3300 and Cisco callmanager only the conference call doesn't work who can help me out
Apr 02, 2009 | Mitel 5212 IP Phone
Jan 13, 2009 | Avaya 4610SW
Making a Polycom SoundPoint 501 work on an Avaya IPO
As you have probably found, SIP phones are not supported until R5, which just came out.
Nov 11, 2008 | Polycom SoundPoint IP 501 IP Phone
Blank Screen
I would verify what the firrmware is of the phone. It is possible that the phones need to be upgraded.
Mar 27, 2008 | Avaya 5610 IP Phone
3Com NBX 3102 IP Phone Logo
283 people viewed this question
Top 3Com Computers & Internet Experts
Mike
Vincent G
Vincent G
Sheldon Dedek
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
