No color display when i play DVD thru component.
Posted by acorn75 on
Frank Fulton
    President:
  • 1,114 Answers
First, check the settings on the DVD player's setup menu for output. Make sure it's set to either Component or Y YB YR or YBPR, and not to "Video". If your settings are correct, check the component cable and make sure it's plugged in correctly on both sides, TV and DVD. If still having a problem, try a new cable.
Finally check the input settings on the TV, if you still have a problem, try using a basic Audio Video cable on the Video out of the DVD to Video 1 in on the TV. That's about as much as you can check. If all fails, if possible, connect the DVD to another TV to check for the same problem to determine if it's a DVD player problem or a TV input problem. Hope this helps!
Posted on Jun 01, 2011
My DVD player only plays in black and white
Hi.
Any Incorrectly connected or defective cables can cause your DVD to display black and white images. If you Are using Component or RCA/Scart Cables follow the below steps :
You must match the colored plugs on the cable ends to the color coded jacks on your home theater and TV
Dec 30, 2017 | Televison & Video
Dvd plays in black only
Be sure dvd player is correctly connected. If you connect the yellow video composite out the dvdto the input on the tv that is not yellow you are probably trying to watch it thru the component in . The component in is 3 wires green blue and red. if all three are not connected the picture will have no color. If you have 3 wire connection on dvd connect it to 3 wire in on tv the other red and white are audio.
Mar 15, 2014 | Sceptre X405BV-FHD3 40 in. LCD HDTV
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
TV color changed to display green only
IF THE GREEN IS ON ALL INPUTS, THEN YOU WILL NEED A DIGITAL AND ANALOG BOARD REPLACEMENT, VERY EXPENSIVE REPAIR, TRY HDMI INPUTS FIRST, THEN COMPONENT AND SO ON
Dec 30, 2009 | Samsung HLT5089S Television
Panaonic Home Theatre DVD system only plays movies inblack white
Check the region and picture settings on the home theatre's dvd player, it could be set to put out a component signal, or it could be set to a PAL region rather than NTSC
Jul 06, 2009 | Audio Players & Recorders
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
YPbPr and YCbCr signal
with component, if there is not a solid signal, it'll go blue. if the dvd is dirty, the player is dirty, or any other break in signal, it'll go blue. clean your dvd and/or player.
Feb 26, 2009 | LG RD-JT30 Multimedia Projector
Daewoo DP42SM coloring missing blue tint on dvd playback only
I don't know are you familiar with electronic,if you are you can fix it by yourself.The problem is in video process board,the one in metal cage.What you need to do is to remove the board from the set,remove the cage, then to replace all SMD capacitors!!!And do not put SMD as replacement put the normal capacitors same values they can be fited.You should aslo replace capacitors at the PSU and check 170V,160V and 70V and adjust them after the replacement.PSU is easy part but the video board is tricky one but it can be done
Feb 15, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
My TEAC PL-D2100 home theatre system, is not showing all natural colors in display since yesterday.
the red rca jack of the component output on your dvd player or the red input on the Avr component input is not plugged in properly ( loose ) or the the component monitor out to the tv may be loose. there is also possablity of cable cut. check it with another component cable or interchange the red to green to find if the problem perssts ,... to ascertian weather it is the cable.. this info should solve your prob.
Jun 30, 2007 | Teac PLD-2200 System
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
