Question about Sharp AR-M160 Laser Printer
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Posted by shaikh939 on
  • francis phin
    francis phin May 19, 2016
    press d copy button then see what error shows, if F-04 comes replace d toner eeprom and F2-40 then replace d developer
zander zamora
    New Friend:
  • 32 Answers
Replace toner catridge and IC reset 14 16
Posted on Feb 13, 2016
ranjithparas
    New Friend:
Sharp.
AR-5516
F2 on screen
Posted on Dec 17, 2012
Shrey Srivastava
    Scholar:
  • 121 Answers
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Posted on Jun 01, 2011
F2 error code toner
Means tonner supply failure. Replace the tonner
Dec 09, 2013 | Sharp AR-M160 Laser Printer
I am using Sharp Copier Model no: AR-5320 and when i replace catridge it showing F2 Please give me the solution?
F2-04- Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
Dec 30, 2010 | Sharp AR-5320 Black and White Copier
While Sharp Copier's tonner change F2 is blinking
F2 means that the toner cartridge is defective or improperly installed.
Toner cartridge must be AR-016T.
Try to put back the old cartridge if you have it and see if error F2 dissapears.
Feb 22, 2010 | Sharp AR-5320 Black and White Copier
I CHANGE THE CARTRIDGE OF THE COPIER AND TURN ON IT. SO THE COPIER DISPLAY MESSAGE 2F.
i think the error your actually getting is F2. this error pertains to toner cartridge chip error. it's that little chip on at the end of the cartridge.you'll need to have that replaced.
Mar 25, 2009 | Sharp AR-M160 Laser Printer
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
What does the error code F2-40 mean on a Sharp MX-M4501N?
according the manual F2-04 means drum data read problem,may be it can be reset why don't give a try;
1, power on,
2, press "clear","interupt", "0", "interupt"
3, press 14 prss start
4, press clear
Dec 16, 2008 | Sharp AR-207 Copier
My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Oct 29, 2008 | Sharp AR-235 Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
REPLACING THE TONER
HI! I HAVE BOUGHT THE SHARP PRINTER/COPIER/FAX/SCAN MODEL AR-M155, WHEN I INSERTED THE NEW TONNER AND MAKE THE PHOTOCOPY TESTING I GOT THE OUTPUT COPY WHICH SHOWS THE HALFED COPY IN VERTICAL ON RIGHT HAND SIDE WHEN YOU READ THAT PAPER SO WHAT COULD BE THE PROBLEM ON IT WHILE IT IS NEW MACHINE???? AM SCARED!!!. PLEASE IWOULD BE VERY HAPPY IF YOU HELP ME TO SOLVE THIS MY REQUEST PROBLEM.
THANKS,
Aggrey34
Sep 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp AR-M160 Laser Printer Logo
874 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
