SOURCE: Dryer will not dry - drum will not turn
Just happened to mine also. The problem was that the Idler Pulley came loose from the drive belt. There is a switch on the idler pulley so that if there is no tension on it, the motor will not start and you will have the symptoms you describe. To reattach the Idler Pulley, remove the back plate surrounding the dryer exhaust. This will give you access to the Pulley. If the belt broke (unlikely with a new dryer such as yours), the fix is more involved. This dryer is the same as the Maytag MDE6700 - you can do a search for a service manual for that model and you can see the details. Hope this helps.
SOURCE: t5 error code comes in my amana dryer ned 7200tw
That is actually a Ts error.
Thermistor Short Sensed
The Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Thermistor is Item #27 HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Testimonial: "very very good"
