Televison & Video Logo
Posted on Jun 01, 2011
My MD-PORT DG2 does not work in my Sony VAIO. "code 10, device cannot start". And my os is Windows 7 Ultimate x86. But when I try it on a windows xp PC,it works,and it also works in the WINDOWS XP MODE on my win7 os.
1 Related Answer
A
Anonymous
  • Posted on Oct 17, 2008
SOURCE: Computer won't turn the device on.
HOLA NO TENGO EL SOFTWEAR DEL MD-PORT DG2 COMO LO PUEDO BAJAR A MI PC PARA INSTALARLO.
Sony Vaio with Windows 7, same message at startup help
Are you able to log into your Account? If so download ccleaner and run registry cleaner. That might work
VPCEB11FM (SONY VAIO) LAN PROBLEM
Look on Sony's site and get the correct drivers, especially the motherboard and network, memory stick and card reader. They are here:Sony.
2helpful
2answers
My sony vaio vgn-cr220E was uprraded from vista to windows 7..why does the biult in motion eye camera doesnt work..
You need the Win7 camera driver, check sony support at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E&SelectOS=44
just enter your Win7 operating system (there are 9 versions of Win7), and select the downloads (2)
for your computer camera driver.
Versions of microsoft Win7 - determine which yours is by (these instructions are for WinXP);
START > Control Panel > System > General (tab)
Windows 7 Home Basic 32-bit
Windows 7 Home Basic 64-bit
Windows 7 Home Premium 32-bit
Windows 7 Home Premium 64-bit
Windows 7 Professional 32-bit
Windows 7 Professional 64-bit
Windows 7 Starter 32-bit
Windows 7 Ultimate 32-bit
Windows 7 Ultimate 64-bit
I loose my bluetooth device when i upgraded my OS from windows 7 starter to windows 7 ultimate. where can i download the bluetooth driver for my sony vaio y series VPCYB15AG?
Try to go to the manufacturer's website. Manufacturer's usually provide device drivers for download.
Here is the link for the Bluetooth driver for your device : Original Drivers and Applications for VPCYB Series : Bluetooth Driver.
Note that this is the direct download. As soon as you click on it, the download will begin.
Hope this resolves the problem.
2answers
I have a SonyVaio VGN-CR220E, I reinstalled my O.S. and now I'm running Windows Vista Ultimate but coudn't install the Motion Eye Camera drivers and it is not working. I downloaded drivers from...
unfortunately, I had a very similar problem with a viao when I tried windows 7 (even with compatibilty mode), it seems that these particular laptops are not upgrade friendly.
2answers
How to restor an original Windows 7 home premium? I wanted to change to Ultimate, but drivers did not worked,
hen the SONY logo is displayed, press the F10> key.
In the VAIO Recovery Wizard window, click the Next button.
under Recovery Options , click to select the C drive recovery option.
click the next button>>finally recovery will be started.
2helpful
Can create shortcut on Vaio Gate
hey just bought a sony and had the same prob, after looking its not to hard, just a quick edit to an .xml.
open the folder %AppData%\Sony Corporation\VAIO Gate and locate the file called VAIO Gate.xml.
Make a copy of this file so if you go wrong you can always restore the ori and start again.
Right click on it and click edit which should open the file in notepad.
Now copy the code i will paste after this, on a new line below into the doc after you find the first </Item>
n.b follow this word for word otherwise it wont work.
everything in between the *need to be replaced with what it tells you. when you have replaced the hints removed the star. When you finish there should be no stars in your code.
This is the code to pase in after the first </Item>
<Item Type="2" DisplayId="app.*first 4 letters of app*">
<DisplayString>*display name you will see in the gate app*</DisplayString>
<DisplayTip></DisplayTip>
<AppPath>*path to the .exe, e.g C:\Program Files (x86)\Adobe\Adobe Flash CS4\flash.exe no need for any quote marks*</AppPath>
<SupportTouch>0</SupportTouch>
<SupportRemocon>0</SupportRemocon>
<WorkDirectry></WorkDirectry>
<Option></Option>
</Item>
thats it save the file, close the gate and reopen it and if you will see the new icons. You can then drag to arrange where you want them in the line.
katg
Top Xitel Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Xitel Televison and Video Expert? Answer questions, earn points and help others
