Tv turned on sounds like a crackle noise after a few seconds then tv turns itself off. no picture. picture over last week appeared slow to present picture - as if it was warming up.
If its an unwanted christmas present, I'm guessing its still under warranty, so call sony. They'll fix it for free. Your problem sounds a bit...irregular.
You have a few boards and components that have died.
Mostly the damage will be on SUST board 2 there will be a number of capacitors that are burned and even split ( crackling noise) The convefrgence chip will also be affected..
Unplugging it resets the failsafe sensor, but after a few seconds will shut the TV down because it detects parts that quickly heat up and report back that all is not well. If you continue to excite it it can even catch fire, so leave it off and have it repaired.
The recommendation is that all 3 boards are changed simultaneously to prevent domino effect. Also it is difficult to determine if the original fault was caused by one of the other boards in the first place.
It is not just a matter of playing board swap jockey as this will end up costing more than a tech who will fix it propely the first time using the right tools, his/her electrical knowhow and the specialised tools that will realign the convergence by generating a hatch pattern on the screen.so that the picture has the right hue and is not 3d in appearance. All voltage outputs match etc.
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
could be that the main b+ filter Capacitor went bad and blew up. Also could have been the horizontal output transistor shorted and the flyback poped. In eather case it would be recommended that you take this set into a repair shop unless your familar with HV circuits in tv sets. Good Luck
