Hello Direct Code Entry To program your universal remote to control your components using the Direct Code Entry Method, follow the steps below. 1. Manually turn on the component you want the remote to 2. Locate the enclosed Code Lists. Find the list for the component you wish to program. Find your component's brand. You will see a listing of four-digit codes for each 3. Press and hold the component key (TV, VCR•DVD, SAT•CBL) you wish to program. The illuminated ON•OFF key turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the illuminated ON•OFF key blinks four 4. While holding down the component key, consult the Code Lists for the four-digit code that corresponds to your component's brand and use the number keys (0-9) on the keypad to enter it. While you are pressing the numbers, the illuminated ON•OFF key turns off. 5. After the fourth number is entered, the illuminated ON•OFF key turns on. At this time, release the component key. If the illuminated ON•OFF key turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry. If you enter a code number that is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the illuminated ON•OFF key blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the
There are four digit and five digit codes that can be synchronised with Samsung TV to RCR312W.
Four digit codes are:
1004, 1005, 1006, 1012, 1013, 1015, 1017, 1019
Five digit codes are:
10812, 10054, 10060, 10702, 10178
Instructions:-
control
brand.
times, and the process is exited
Direct Code Entry process from step 3.
Tip: Throughout the programming of each key, be sure to keep the
remote pointed at the IR sensor of the component you are currently
programming the remote to control
6. To confirm that the component key is programmed with
the correct code for maximum functionality, test the
component. Attempt to control a variety of the component’s
functions with the remote. If some of the features of your
components do not work, try programming the remote with
a different code in the list until you find the code that allows
the remote to control the majority of your component’s
functions. Different codes can provide different levels of
functionality
