Question about Fitbit Weight Tracker
I have tried recharging my fitbit by docking it and it is still blank. I have tried using a pen and pushing the bottom - even turning the fitbit around on the docking and pushing it with a pen but still blank.
Posted by ltmiya on
  • 1 more comment
  • ltmiya Jun 06, 2011
    it did not work at all.
  • Anonymous Mar 18, 2014
    fitbit started buzzing randomly and more often. Now it's using the battery much faster than normalAs it is buzzing so often it is also giving me steps even though I have taken it off my wrist
  • Anonymous Mar 28, 2014
    FITBIT ONE AND ARIA SCALE NOT TURNING ON OR RESETTING
Reynaldo Labaguis Jr.
    Genius:
  • 1,157 Answers
Hi ltmiya,
Resetting the device to its factory setting will determine if the problem is either a software or hardware failure. In your case, this is a hardware failure ( display issue ). You may try to contact fitbit support at [email protected] to have a service option.
In addition, you may try to reset the device again using the steps below.
1. Place the tracker on the base station.
2. Using a paper clip or a pen, push the button on the bottom of the base station.
3. Now, the tracker should restart and display the firmware version. Sometimes it's FITBIT ver 1.0..
Hope it helps.
Thank you for using FixYa.
Posted on Jun 06, 2011
Jose Cada
  • 3,530 Answers
Welcome to Fixya
Pushing the hole on the gadget is like resetting the unit. This usually fixed all problems that you might encounter to the unit, just like a reset button on the computer. If you already did that and there is no response from the unit, the problem is more of a hardware/internal issue. You might need to contact the manufacturer for repair or call the store and ask for replacement if it is still under warranty.
Thankl you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Jun 01, 2011
My fitbit seems "dead". Tried to charge it but no reaction...
Hello, Tony -
Did you check the FitBit web pages for information and troubleshooting regarding your FitBit not charging?
See the information on a FitBit web page here:
http://help.fitbit.com/articles/en_US/Help_article/1190/?l=en_US&c=Topics%3ABattery&fs=Search&pn=1
The last option listed on that web page is to contact FitBit Customer Service.
You may need to replace the battery in your FitBit. Note: Rechargeable batteries do not last forever and eventually need to be replaced.
Best wishes.
Jan 21, 2018 | Exercise & Fitness
How do I charge my fitbit zip battery?
You cannot charge the Fitbit Zip as it uses a coin battery.
The Fitbit Zip runs on a replaceable 3V coin battery, CR2025.
It can be found wherever batteries are sold.
You can change the battery while not wearing hence counting steps. Fitbit Zip Battery Change
Mar 15, 2016 | Fitbit Zip Wireless Fitness Tracker
My fitbit flex died - cannot wake it up; also it's tied to my cell phone and that doesn't respond - totally blank!
How to fix broken Fitbit - sync Fitbit with phone app - PC ...
www.pcadvisor.co.uk/how.../how-fix-broken-fitbit-sync-image-3499292...
May 15, 2015 - Fitbit Flex, Fitbit One, Fitbit Zip, Fitbit Force or Ultra not syncing with the Fitbit app ... To get the Fitbit app sync working again restart the Fitbit tracker. ... charger, has a battery charge but is not lighting up, or isn't tracking your steps. .... I've already done all the obvious stuff: turning off my phone, turning off and ...
Fitbit Flex review - The disappointment we've all been ...
blog.hyperexpert.com/fitbit-flex-review-the-disappointment-weve-all-be...
May 5, 2013 - My wife and I are both in good shape, we both wanted the Flex just to ... app, wait for the device to finish connecting and syncing to your phone, ... to sleep mode, I have to do all of this? and then again to wake it up? .... Also, doesn't the manual say "not" to wear it in the shower? ..... I appreciate any response.
Jan 06, 2016 | Fitbit Flex Wireless Activity & Sleep...
Wireless just stopped working. Changed batteries,
The behavior described indicates weak/dead batteries. Logitech brags about the battery life on this model, but in reality battery life varys dramatically between invidual units. I've seen one that would not operate at all on Ni-Cad rechargable batteries (only 1.2 volts even at full charge). If you must use rechargeables, stick with NiMH (metal hydride). Better yet, use long life lithium.
Also, make sure the "Nano" receiver isn't sitting in the storage bin. This is one of two ways to power off the mouse. The other is the 'Clip N Go' dock.
Sep 24, 2009 | Logitech Cordless Mouse
Blank screen
Try soft reseting your phone. If that doesnt work then try hard reseting.  To soft reset take the stylus pen and push in the little hole on the bottom of the phone. You should feel a little click and then your phone will restart. Wait until your phone  starts up again and if it still isnt working then do a hard reset.
 To hard reset, hold down the green send button and the red end call button at the same time and continue to hold them down as you then push your stylus pen into the hole on the bottom of the phone untill you feel the little click. Your phone should start to reset.  Be warned you will loose any information saved to the phones memory ie: phone numbers, pictures, personal settings. Anything saved to your memory card should be ok.
If your screen remains blank after trying both resets I would suggest taking it back to where you got it and and have them fix it or replace it.
Hope this is helpful.
Feb 12, 2008 | HTC Touch P3450 Smartphone
Fitbit Weight Tracker Logo
2,077 people viewed this question
Top Fitbit Facebook Apps Experts
Andrew Taylor
Andrew Taylor
ray gallant
Harrie
Are you a Fitbit Facebook App Expert? Answer questions, earn points and help others
