Question about Brother MFC-845CW multi-function All-In-One InkJet Printer
Brother MFC845W not printing
This printer has worked beautifully over a wireless network in our home for almost a year now. Recently, and inconsistently, when I send a document to print from my laptop it won't print. If I click on the printer icon at the bottom of the screen it says error in the status button. If I turn the printer off and then on, and re-send the document it will usually print...and will usually print OK for a few hours after that. It's as though I have to keep re-setting it. I noticed this all started after printing a large file from a University which printed very slowly (I mean like a line every few minutes). It hasn't been the same since. I notice a blue bar on the function screen on the front that says Mem and the blue bar is full. Perhaps unrelated. Any ideas?
Posted by klwisner on
5 Related Answers
Anonymous
  • 26 Answers
SOURCE: Brother MFC-420CN color ink empty but want to print/copy in B&W
brother won't print od do anything is one of the 4 inks are empty so first of all you have to replace whatever is empty, when you remove it it will ask you if you changed it and if it is a new one you will press 1 twice per cartridge, if you put compatible ink in you will clog the ink head up and then be stuffed
Posted on Dec 15, 2007
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: Brother HL 5250 DN status shows "error". Won't print.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
Anonymous
  • 7 Answers
SOURCE: printing from XP to a Brother 7820N as a networked printer
We have multiple 7820s in our office. This would be a configuration problem with your windows XP computer. From the XP computer, open a command prompt and type "ping x.x.x.x" where x.x.x.x is the ip address of the 7820n. Make sure you get four successes. I would then uninstall the brother software and drivers and go to "printers and faxes" in the control panel and manually add the printer.
To manually add a network printer, with it's own print server, on Win XP:
1 Click "Add Printer"
2 Select "Local Printer Attached to this computer"
3 Deselect "Automatically detect and install my Plug and Play printer" then click "Next"
4. Click "Create a new port" and select "Standard TCP/IP" from the drop down. Click "Next". this will open TCP/IP Wizard
5. Type in Printer IP Address next to IP Address (Port name will autopopulate) and click "Next"
6. If wizard finds printer, it will show you "Finish" button. If you get a "Additional Port Information Required" window, something is wrong with your printer or windows xp network configuration.
7. When the TCP Wizard window closes, it will take you back to Add Printer Wizard. Select "Have Disk" and navigate to the \USA\WXP\Addprt directory on your Brother Drivers disc.
8. Select brxpadd.inf and click "Open" then click "OK"
9. Select "Brother MFC 7820 N Printer" from the list and click "Next"
10. Select name of printer, whether you want a default, print test page and DONE!
Posted on Apr 30, 2009
Anonymous
  • 3 Answers
SOURCE: Brother MFC-790CW Printer is not receiving any
this printer uses a 3rd party program to print over the network. try reinstalling the CD software. This will fix it. The problem is that the printer gets lost on the newtork if the router reassisgns it a new IP, other than 192.168.1.66 that it expects. Routers may do this upon resetting. You can reserve the ip address in the router settings, and make it static in the printer, but that is more work. If you can USB print to the printer, this is all that is wrong.
Posted on Jan 19, 2010
Swarnava Palit
  • 114 Answers
SOURCE: My Brother 5240 laser printer has a red status
It may some paper jam inside your printer . open the front cover pull out the cartridge and look any jammed paper is there or not. if not the the problem may came from your toner drum.
Posted on Jul 18, 2010
Brother MFC-J615W says offline
Go into control panel, open up printers and devices, select printers, find your printer and double click. When the printer comes up you will be able to choose that printer to be online.
Feb 07, 2015 | Brother Office Equipment & Supplies
Using brother printer on airport express
Have you set uo a home network? Do you have your printer sharing with your home network? your printer, Brother MFC-6890cdw, is not wireless, is that correct? You can print through a Home Network, wth a sharing Printer, but the printer must be compatible with Apple Air to print with Apple devices. That said, you can download a App for E-Print on the Ipad. It can be done with exceptions.
Nov 12, 2012 | Averatec 3360-EG1 Notebook
Our brother printer wireless hl 3070cw will not print, it is telling us that it is ready but will not print
it would have print archive in its job print .. check and delete . or install printer again .
i hope it shall work .,
Mar 29, 2011 | Brother HL3070CW Compact Digital Color...
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
Printer Setup & Support Call 1-(805) 225-6690 We are Available Call Now For Help..
You can attach the printer directly through USB cable to your computer and print, or you can connect the printer and your computer to the same wireless network and then print using the wireless and your connection.
Internet is not necessary, only a communication path needs to be established. For this whether its your neighbor's wifi network, your own wifi network, a usb cable connection between your pc and printer etc printing will be accomplished.
Dec 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
Wireless connection!
Yes. Keep it plugged in to your desktop.
Do you have your home network configured? That has to be done first, between your desktop and laptop, etc., then under the printer's properties select "sharing", and share the printer from your Desktop.
Then to access the printer on your laptop, go to "add printers" Select "network printer", then select "browse", then browse your network for the "shared printer", and select it.
You will only be able to print through it if your PC is turned on.
Jun 19, 2009 | Brother Office Equipment & Supplies
Networking
It isn't a network printer since it only has a USB interface (no LAN port)
http://www.brother-usa.com/VirData/Content/MFC/ModelBrochures/Brochure_MFC240C.pdf
but you may purchase a print server if you want to share the printing function on your network (only the printing function can be shared). But some multifunction printers do not work with print servers due to driver issues. There are some users on the net who were able to make this work with an IOGEAR multifunction print server.
There is one Brother multifunction network printer that you may want to check:
http://www.amazon.com/Brother-MFC-7840W-Multifunction-Wireless-Interfaces/dp/B0016ZQ566/ref=dp_cp_ob_e_title_1
Dec 11, 2008 | Brother MultiFunction Center MFC-440CN...
Stopped printing PDFs and Web pages
those your printer support wireless printing? if not try to check if it is bluetooth capable
Jan 09, 2008 | Brother HL 1440 Laser Printer
Brother MFC-845CW multi-function All-In-One InkJet Printer Logo
131 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
