Question about Logitech Radio Communications
How do I get rid of soft clicking noises in my recordings?
bsc1015
    New Friend:
  • 20 Answers
The soft clicking noises could happen for many reasons such as moving your headset around, tapping on any part of the headset or even the wire, but if it's for none of these reasons, then it could be because of a loose wire.
Posted on May 31, 2011
I wish to transfer my vinyl records to my Brennan JB7.My record deck is a B&O Beogram RX2 2 phono plugs only,black & white. How do i do it? Thank You. Les Hillier
Having looked at the Brennan it can't record music only copy it.
So what you need is some software such as Magix Audio Cleaning Lab. This will record the music from the record player and get rid of the clicks and noise from the tracks.
You also need a converter, these are simple enough and you can get them from Amazon. See image below you can even transfer video with the yellow RCA or SVHS lead. Your deck plugs into the red and white jacks and the usb into the computer. Once recorded you can transfer the files to the Brennan.
Jan 24, 2018 | Audio Players & Recorders
Get rid of background noise
Well Adam,
was the environment already noisy?
Well but there is a program (Nero Wave Editor) which can help.
On the interface, click ENHANCEMENTS on the top and then select NOISE REDUCTION and it will present you with some other interface with sliders and then you move then more to the right.
Standing by anyway
Apr 15, 2014 | Olympus VN-711PC Digital Voice Recorder...
What do noise gates do?
A noise gate is a software that is used to get rid of noise in a recording that you don't want.
Nov 25, 2013 | Audio Players & Recorders
Wont start makes clicking noise
Sounds like you need professional service from your local Apple store. There is a click maker inside them which you can disable. Why yours is clicking on its own is because there is a fault.
Try a Soft Reset. Hold the Play Button and the Centre Button
ipod touch just makes clicking noise Google Search
Dec 13, 2017 | Apple Ipod Touch 1st Generation 16 Gb Very...
Can't get rid of background noise on my marantz pmd660
Did you ever find a solution to this problem? I have tried new AC adapter cord and it still has background noise. The only time it doesn't is with the batteries.
May 15, 2012 | Marantz PMD660 Digital Voice Recorder
Straight noise in the recorded clip
Make sure the webcam mic is set as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
You may be getting feedback from your speakers to your mic
Check by using a headset
May 05, 2010 | HP Elite Autofocus Webcam
How do i record music from my djm 700 to my laptop
Has your laptop got an audio input socket? If it has you can plug your turntable into that. You might need some kind of adaptor plug to connect, but your local electronic shop should be able to supply you with it. When you have the sound going in you will need software to record it, I would recomend Magix Audio Cleaning Lab. This will allow you to record the signal, plus being a record get rid of the clicks and other noise. It will take a bit to get used to but you will soon learn. You can get it fairly cheap on Amazon.
Oct 23, 2009 | Pioneer Audio Players & Recorders
Noise from nouendo recording
What you need is a Plug-in, Either a NOISE FILTER or DNR (Dolby Noise Reduction) Also try when you record to set up the Mic away from Speakers, Equipment, and watch your lights. These are all Noise Makers on Tracks. Even Guitar and Bass to close to Monitors will give you added noise. If you can not find a Plug-in then pull up an EQ, Find the Frequency making the Noise, Adjust the "Q" (Range of Frequency) to be NARROW, Then slowly pull down your unwanted frequencies. This will get rid of Noise, But also anything else in that Frequency! Good Luck!
Apr 29, 2009 | Steinberg Nuendo 3 for PC
Clicking noise
Is the clicking louder, and faster, the faster you are fast forwarding and rewinding? If so, it's just be the drive reading the video back. Mine is very quiet and I only softly hear it when there is no sound, like when I FF. Can you move the box into an entertainment center, or further away from the TV?
Mar 15, 2009 | Pioneer DVR-107D DVD±RW Burner
Buzzing Noise in Sound Studio
hi, check all cables,clean connections. i have had these kind of problems in the past. also coulb be ground loop!? hope this is helpful.glen
Feb 15, 2009 | Apple Griffin iMic External Sound System
Radio Communications Logo
164 people viewed this question
Top Logitech Radio Communications Experts
Ekse
Marvin
Marvin
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
