Question about Belkin F5D4074 Network Adapter
I have had a pair of Belkin Powerlive AV adapters (F5D4072) for a while now and they work really well across my house between two routers. I recently bought a 2nd pair of the newer F5D4074 adapters (old model is discontinued ? and the new ones are said to be compatible anyway). I can get them all to 'pair up' with their encryption codes when using an older one as a 'master' but not always successful with a new one acting as the main key-setter. In either case I am having difficulty getting the data to pass between an old and new adapter (or vice versa). Two new and two old ones work happily with each other as compatible pairs, but not across the model range - I have tried for many hours resetting and generating new keys etc in a fairly controlled environment - using a 4 gang non-surge socket to 'bridge' them together. I did manage to get data to initially pass (briefly) just after 'powering up' one of the mixed pairs, but after a short while (not an idle time) this connection appears to become 'broken' and is not sustainable. The middle led of 3 is illuminated to show a connection is formed but this does not seem to guarantee the routing of data. Does anyone have any ideas how to get Belkin F5D4072 and F5D4074s to work as a set? (One to be connected to the internet router and the other 3 servicing: 2 PCs and a TV)
  • Belkin Master
  • 7,733 Answers
There are two standards for powerline: HomePlug 1.0, which has a maximum link speed of 85Mbps and HomePlug AV, which has a maximum link speed of 200Mbps. You can use the two standards within the same building, but they are not compatible with each other.
HomePlug 1.0 - F5D4050, F5D4070. Powerline Turbo (F5D4071, F5D4073)
HomePlug AV - Powerline AV (F5D4072 + F5D4074 + F5D4077 + F5D4081). Powerline AV+ (F5D4075 + F5D4079) + Powerline HD (F5D4076 + F5D4078) and Powerline HD500 (F5D4085)
Posted on Apr 10, 2013
1 Related Answer
Anonymous
SOURCE: I have 4 Belkin Powerline
I too have the same configuration. I reset all the boxes to their factory settings and connected them to one another on a single 4 gang extension lead (not a surge protected one)
I could get their passwords to pair up as the middle led would indicate. But I could not get the data to freely flow from an old device to a new one!
One step forward...
Posted on May 31, 2011
2answers
I have a belkin wireless G+ router work with a power link adapter?
Just use the unused one to create an access point.To do so you need to login on the web UI of the router and change to an access point instead of a infrastructure.
I have just bought Belkin Powerline AV starter kit. I have a Belkin N1 Wireless Modem Router connected through a Carrier PoE adapter. I have tried to connect my Sony TV and PS3 through the powerline units...
Try reset the device and start a new configuration.It seems that your networwork have issues between the router and the powerlines.All need to be in the same network as per router configuration.Connect one adapter to your router and plug it into an available electrical outlet. Plug the second adpter into an available wall outlet and connect the other end to any device with an available Ethernet port such as a gaming console, set-top box, or computer.
pd: OS to use the adapters; Windows 2000, XP or Vista.
I have 4 Belkin Powerline adapters, two F5D4074 and two F5D4072. On Belkin website they are declared compatible, but I can't manage to transfer the password between the 72 and the 74, with the result that...
Also try to rest the adapters and reconfigure them again.
One step forward...
I have a belkin -n1 wireless router.. it is a great router because it works all the way through the house. the only problem with it is that i cant update my xbox with it, neither by wire or wirless. if it...
first check whether the gaming ports for xbox have been forwarded in the belkin router or not....if not do it first....if you dont know the port numbers call xbox support and get the list of port numbers to be forwarded....
then enable DMZ for the ip address of XBOX in belkin router...
then enable UPNP in belkin router....
atlast Disable firewall in belkin router.... your XBOX will go online and GET UPDATE..... you can call belkin tech support of your country to assist you to forward ports for XBOX in belkin router... if you reside in USA/Newzealand/Australia/Canada you can call this toll free 1800 2 BELKIN(235546)...... or you can call my personal mobile... Im from India country code +91 Mobile number 9003593572
2helpful
Belkin powerline adapter doesnt connect to internet
try resetting the adapter
if not working try updating the firmware
if not working make sure ur adapter is pluged in the same power(electricity) phase of ur house with the router
the house will have different power phase so make sure of it
both the router and the powerline adapter must be in same phase of electricity
Belkin router not working with 2wire wireless adapter
Your SSID should be same then you can connect that network.
Trouble expanding my Belkin Powerline network
F5D4075 uses Homeplug AV standard and F5D4071 used Home plug 1.0 Turbo. Both are not compatible to each other. So if you form a network, you have to form with the same standard.
Secondly, You need just one Powerline adapter on the router and you can have 2 or 3 adapter connected to 1 computer each and all these computers can connect to the 1 adapter on the router. You do not have to use it in pairs
2answers
D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
Belkin F5D4074 Network Adapter Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Resolution IT Dubai
Resolution IT Dubai
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
