Then it cuts when hot ?
when cold start is it take some time to run from clod ? if yes then injectors nozzles if not then it is the (coil) well cut off when engine is hot
(Fuel Rail Pressure Sensor Circuit Range/Performance is official verbage for code) that exactly what code tells you
but i can be more specific and tell you
when the injectors got older and older they dripping the fuel rather spraying it and her comes the problem and when heats up the nozzles expand due to heat and its already old and got wider hole thats how it makes you a trouble and you should also notice an increasing fuel consumption
or it could be very simple problem if u are luck it could be just the fuel filter
Why would it run for a week or so just fine and then this morning not start after sitting all night? Does the P0191 code have something to do with the fuel injectors? (Fuel Rail Pressure Sensor Circuit Range/Performance is official verbage for code)
