Panasonic SC-HT830V System Logo
Question about Panasonic SC-HT830V System
I have a Panasonic DVD/VHS Home Theater SC-HT833V. Everything is working except for my VHS. I can hear the VHS tape playing but cannot see the picture. The DVD works fine I can see and hear it.
Posted by tunetown4 on
Anonymous
    Brigadier General:
  • 3,301 Answers
Clean the heads of the VHS machine,, if they are clean,, check the video wire connections( the yellow one)
Posted on May 31, 2011
What soes W2S flashing on my Panasonic Home Theater mean
you need to go to the menu and move the audio setting.
My power went of a for about 8 hours last night and when the power was restored everything works except I cannot hear sound on my BT730 sound system while listening to TV through the cable box. I can hear...
Trace the TV audio back to its source - TV or Cable Box most likely. We have no way of knowing which. Substitute in another source to test the input.
If DVD audio works so does the basic HTS.
Panasonic DMR E20 Produces a line of distortion along the bottom
Sounds like you see head switching from the tape. Most TV are over scanned enough to hide it.
1helpful
Lg super multi dvd recorder/tape player (RC 199H)
Drive needs to be replaced.
Common problem.
1helpful
Panasonic Home Theater SC-HT80 "NO DISK"
The problem is that the DVD section is not working properly and can not detect the disk. Try a music CD. If that works, then the problem is either a dirty lens that is not allowing sufficient laser light through to read teh DVD or the optics are failing and need to be replaced. If you can post the model number, I can give you an estimate for the repair cost.
Dan
2answers
SC-DK20
That home theater system is not decoded to play those copied disc try using maybe a different brand name CD-R/DVD-R when you make your copies.
My panasonic SC-HT830v DVD/VHS Home theater... Dvd drive will not open or close
try to apply a good brand contact cleaner(from radio shack or other electronic store near you)and press it many times.
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
