Question about Sony Playstation 3 (PS3) Console
Turns off cuts out during dvd playback and gameplay
I read your blog mate i think i agree with you i have the same problem with my ps3 as i am a mechanic by trade and fiddle with eletronics in cars and the same thing happens to them and they just stop dead in the middle of the freeway so looks like i will be pulling my ps3 apart and filling it with heatsink paste
5 Related Answers
Anonymous
  • 13 Answers
SOURCE: freeze-up
How old is this ps3? Is it the newer cheaper, or the older, more expensive one. Their are differences in the systems.
Posted on Nov 29, 2007
Anonymous
SOURCE: During DVD movie playback, screen goes black periodically
it could be that the disc is and ordinary dvd disc and cannot stand the capability with a high def tv because i have the same problem and when 1 put a bluray disc in its fine
Posted on Mar 11, 2008
Anonymous
  • 14 Answers
SOURCE: error 8001002B
That is the common "dirty disc" error. If it happens with every game, it more than likely means that your Blu-Ray diode is dirty. Do you have the PS3 in a dusty environment? Be sure to clean the vents on the side, above the USB ports and on the back of the PS3 on a daily basis. A quick swipe of a soft cloth will do.
You can try several solutions for your problem, the most common to buy a can of air and blow it inside the disc drive in hopes of cleaning the diode. You can also try a CD/DVD cleaning disc.
If it happens with every disc this could also mean a dreaded Blu-Ray drive failure, or in your case, one that is in the process of failing.
If cleaning it does not work, I highly recommend you give Sony support a ring.
Posted on Jan 26, 2009
Anonymous
  • 30 Answers
SOURCE: PS3 Freezes after 20 mins of gameplay
PS3 is one of the most amazing gaming device but like other competitorgaming devices (Xbox and Wii) It also has some problems like Freezingup. You may check out the informative Article at ezinearticles. Remedy for PS3 Freezing up.
Posted on Feb 21, 2009
RescueTechLA
RescueTechLA
  • 2653 Answers
SOURCE: my ps3 freezes when i
You might want to start with a System Restore and a firmware update. Also a controller reset might be in order too.
Check out my common problem and easy repair guide here:
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and don't forget to rate!
Thanks!
RescueTechLA
Posted on Feb 23, 2009
My ps3 keeps freezing during games
Problem: Your Playstation 3 console is freezing during gameplay. There are usually two problems that would cause your Playstation 3 to freeze during
gameplay. I will start with the most common problem:
1. The Blu Ray Laser is wearing out. This is a common issue among the newer video game consoles. The laser is constantly lighting up to read the discs while you are playing your Playstation 3 whether you are playing games, Blu Ray movies, or DVD movies. Eventually the laser will burn out. As it starts to wear out, first the games or movies will freeze. After a while, it will not read Blu Ray at all. Finally it will quit reading anything. You can find lasers at the following website starting at $49.95. The same website also performs repairs of the Playstation 3 console:
http://store.richspsxparts.com/pl3paac.html
2. Overheating. This is less common. If your PS3 freezes and you shut it off and back on and it comes on ok, it's probably not overheating. If heat is the problem, it will freeze right away if you turn it back on right away without giving it time to cool off. If it turns on OK with no problem and doesn't immediately freeze up, the laser is your issue. If you turn it back on and it freezes right away, your PS3 may be overheating.
If your PS3 is overheating, the best thing to do is to make sure you do not keep it in an enclosed area. Playstation 3 systems and XBox 360 systems run very hot. You must keep it in the open so it gets as much cool air as possible! You can also upgrade the fan inside of your Playstation 3 with the Whisper Fan which increases cooling. You can also find it at the following website:
http://store.richspsxparts.com/newpl3ps3taw.html
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
I have had my sony rdr-gx257 dvd recorder for about a year now, never been used. I have been recording gameplay from my ps3 with it since yesterday. I have recorded onto dvd-r disk and dvd+r disk however...
After ending recording, Finalize recorded dvd as option is available in recorder menu.
a Finalized dvd will playback in other dvd players.
Thanks.
Dec 30, 2010 | Sony RDR-GX257 Player
Region code blocks DVD
Hi, you have to delete de region coding on your DVD, by using a computer (either a mac or PC, or linux) then you can play it. However, if the format is not the same (PAL&NTSC) it's gonna be impossible : for instance, if your PS3 is NTSC, you wont be able to playback PAL content, however, I think it might be possible to the opposite for PAL PS3 owners, since every PAL DVD player can read NTSC (but practically, none of NTSC player read PAL ...) Sad indeed mate.
Its a pain in the *** willing to try converting PAL to NTSC. You better forget it .... However, if its just a region code issue, as I said first, you can just backup it up deleting the CSS (it's illegal... whatever) and burning the region-unlocked movie to a blank DVD and play it ^^
Aug 21, 2009 | Sony Playstation 3 (PS3) Console
My PS3 display is flashing...
On the XMB go to Settings ---> BD/DVD Settings ---> BD 1080p 24 Hz Output (HDMI). Turn that bad boy off.
Give that a shot.
Feb 20, 2009 | Sony Playstation 3 (PS3) Console
Code displayed over my ps3 xmb, affects gameplay
video rsx cpu maybe partially damaged..i can probably fix it.
Nov 10, 2008 | Sony Playstation 3 (PS3) Console
Ps3 controller issues
Have you charged the controllers in a while. The controler might just be running out of energy to work.
Apr 05, 2008 | Sony Playstation 3 (PS3) Console
Freeze-up
Nov 28, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
57 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Lee Hodgson
Lee Hodgson
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
