Question about Acer AL1711 17" LCD Monitor
Acer C708 17" monitor vertical
    Guru:
  • 767 Answers
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Why in my Acer monitor AL1717 comes vertical lines in middle of the screen ?
Try updating your display driver and also try with another monitor cable, in case its broken.
Apr 28, 2014 | Acer AL1717 17" LCD Monitor
Display vertical line
Turn off the monitor and disconnect it from the back of the pc. This way you will isolate the monitor from the PC. Now turn on the monitor, if you still see the vertical line then that means the screen is bad and you would need a new monitor.
If the monitor doesn't have the vertical line then that means your video card is the issue or if you have an integrated vga port on the back of the computer then the motherboard is bad and would need to be replaced.
Sep 23, 2013 | Acer V173 Monitor
A vertical line in the middle of my Acer P221w monitor
dead pixels?? although im told dead pixels are red.
Feb 16, 2013 | Acer Computers & Internet
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Jul 29, 2012 | Acer Aspire Computers & Internet
I have home pc getting vertical line in my acer monitor help me how to remove line
Is this a lcd monitor? Vertical lines in LCD panels are generally caused by a bad panel. If this is your problem the lcd panel can be replaced but may not be cost effective.
Please rate this solution if it has helped you.
Thanks, Gary
Jul 13, 2010 | Acer Aspire™ T180 PC Desktop
Getting vertical line in acer monitor
Apparently it is a display hardware problem. Try another monitor with the same cable and video card. Then you should try another cable. Then another video card. If vertical line doesn't show in either case, then you should replace the appropriate device\cable. If it shows anyway, then bring your monitor to service center for diagnosis.
Vertical lines in the monitor
Vertical lines from the top to the bottom of the screen are due to failing T-CON board (part of the LCD panel assembly). You can try reseating the ribbon cable attached to the T-CON board, otherwise new screen will be needed, these failures are due to cheaply made screen by company such as Chi Mei. It willget worst with more lines.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Jun 04, 2010 | Acer AL1715 17" LCD Monitor
A vertical white line appears on my LG L1520B 15 monitor
This is a horizontal sync circuit gone.
In English, probably cheaper to replace than repair.
Wouldn't hurt to get a quote if it is free.
Jul 29, 2009 | LG L1520B 15" LCD Monitor
How to change the resolution of Acer AL1702Wb 17
On windows XP and earlier :
1. Right Click the desktop
2. Click properties
3. go to settings
4. the resolution slider is there. Try different resolutions untill it looks good.
Feb 21, 2008 | Computers & Internet
Acer AL1711 17" LCD Monitor Logo
85 people viewed this question
Ekse
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
