Question about Belling Ovens
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
Posted on May 31, 2011
Testimonial: "Cheers, sounds good"
Fitted the new element but it didn't work either...
you will need a multimeter, get to the connections when Isolated from the mains , make sure thay are secure. then with great care select A/C above 250 range if not auto ranging, switch on the power, switch on the grill , some models you have to switch past the top over it has a sign with a horizontal coil, switch to this if no heat from element, measure the voltage holding the insulated part of the probe, If no reading, switch the main power off, then look at the back chassis the should be a component mounted on it behind the grill element, this location varies depending upon model.
with power off examine if there are any signs of burnt replace, the numbers are essentual to obtain the correct one, if no burning check with the meter with the power isolated for continuity, put the meter in resistance low level there should be continuity, between the pins if no contiuity replace the component and try again, let me know how you get on.
Regards
John
