Audiovox FPE3206 32 in. LCD Television Logo
Question about Audiovox FPE3206 32 in. LCD Television
FPE3206 - I have blue power led lit and no pic or audio. Thought it was the inverter but wasn't. Power supply has 5v. Did not get the 24v reading. I have 2 bad surface mount resistors on the main. So i'm looking at the SMPS and the Main. Any suggestions? Thanks, James!
Posted by levonmarie37 on
Chi Chu
  • Audiovox Master
  • 8,457 Answers
The tv main Tuner signal board it is dead and it is the causes,if u have 2 burn surface mount resistors on it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole main Tuner signal board for the replacement.
Posted on May 31, 2011
Vizio M50-C1 UHD 4k Audio only no Video Black screen Which board to replace?
Mostly is the back lights strips, you may use a led check to check it out.
Power Supply Issue - Green LED ON..no power up
tried to disconnected the 24v supply connectors going to the power inverter board which may the cause of voltage drop. after you disconnect then if still no output 24v dc coming from the power supply board the cause will be bad power supply board. check for an open resistance or bad regulators going to the 24vdc out. by the way you should connect all the connectors going to the main board to turn on the processor and the inv_on voltage going to the inverter board.
Lg 47lk520 reset
tried first to disconnect the supply connector going to the inverter board for back light just to ensure if their is no shorted component here. and then turn the power on again if the light stay then the inverter board was the cause why won't power on. by the way did you make a voltage checking at the power supply board does it have correct output voltages 5v,12-16v and the 24v.
Power but no picture
you need to check weather the power supply has complete output dc voltages 5v stand by, 5v detect 12v-16v for audio and tuner and 24v for back light. if just only an stand by voltage, the cause is either the power supply failed or the main board detect an error in the inverter board .
Hi, when i turn on my tv model number (42lc7d-ab) i have no picture or sound. thanks
I would suspect the power supply is faulty:
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
If you repair the 24v line on the power supply and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will also need a new inverter.
Hope this helps! Please rate
My audio works fine but no picture.I was told to check the fuses but dont know where the fuses are located at
The slow-blow white fuse is located nearest the point of where the power cord of the tv first contacts the power supply (middle-board, usually)
However, I would suspect the backlight inverter is faulty:
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the ps_on (on) the backlight inverter and you still have no picture...you will need a new inverter.
Hope this helps! Please rate!
1helpful
Fuse and power supply look ok to the eye slight static sound on audio tiny flash intermitent inright corner on video, any clues? power diods check good ,nothing looks hot or burnt There is a second board...
Your power supply on the dc output should have the floowing DC voltages, 5v, 12v, and 24v. Just start probing the connectors of the power supply. 24v is needed for the backlights inverter board, 12v for sounds, 5v for logic board.
13helpful
2answers
LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Westinghouse LTV-32w6 power light on, no video, no sound
One thing is to make sure the inverter board is unplugged when testing the voltages. A shorted inverter will shut down the power supply if the fuse dosen't blow first. There are fuses that don't look like fuses so they can be missed. The next thing would be to look for a connector from the main to power supply and see if there is a pin labeled power on or p.on or similar. The main board should turn this line high(5V) when you push the power button. If not you probably have a bad main board. Unless you can find good used boards they are both expensive. Around $200 for PS and $300 for main.
3answers
LT26HVE issues
Maybe a class action lawsuit is the answer
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
