Most likely the dimmer switch it dead. Turning it back and forth, Fast several times , sometimes will clean the contacts and it will start working again, for a while.
I own a Craftsman rider, DTY 4000, 25 HP Kohler, 48" cut, 137 Hrs. It eats a belt about every mowing or two. Did all the stuff you did. Good luck from Sears. Had cousin who is owns a lawn & garden repair business look at it today. Says the prob. is this - The drive belt pulley (elec clutch) has too a narrow "V" and the angle of wear between it and the deck when the deck is in the lowered (mowing) position is too severe. If you notice with the deck in the fully raised position the pulleys line up perfectly. Then drop your deck and see how tightly bent the belt is downward and it makes sense as to why(my) belt would first roll over then break in a few minutes. The elec clutch pulley is sold as one unit PT No. 179334 $250.00, but I'm sure it would come with the same narrow V pulley. Waiting for word from my cousin. My last Sears Mower. Cannot even sell it in good faith.
insert a disc cleanser first then play it several times,maybe the laser contained a dusts. mostly original disc driver are choosy,they can not read pirated disc..if your disc driver still not working, your laser might be defected.pull out your laser then change a new one..i hope this may help you,
More then likely when the DS hit the floor the board ended up having hairline cracks in them. Hairline cracks in the main board of the DS will cause the DS to not turn on fully. Get the DS replaced.
mitsubishi 45605 . I bought a universal remote and it wont respond anymore. I tryied reprogram and it wont take the old code or any code. I bought a new remote and it wont respond
Erm, maybe because you dropped it.. just guessing. Anyway cellphones as other hi-tech appliances are very very touchy on the subject of handling.
You can drop your phone from the 3rd floor and and still be able to use it and you can drop it 50cm and it'll be broken beyond repair.
In your case something might have burned out or a connection severed in either case your best bet is repair if you have insurance (drops aren't covered though) or buy a new one.
P.S. You can also try dropping it again if there is nothing to lose...
