Question about Lanzar (MAXP154D) 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker
What is the rms wattage on a lanzar max pro 15"
Posted by dallas_co140 on
Anonymous
    New Friend:
  • 24 Answers
1000watts RMS and 2000 peak
Posted on May 31, 2011
Bain
    New Friend:
  • 25 Answers
NO its more like 500 rms if that. be careful because of the voice coils come unglued on all of their cr ap.. i had one and a 6.5'' matching set... unglued! and, if you have a lanzar amp thats 4000 watts peak and 2000 rms its truly like 300-600 rms depending on model and year. only true power is from opti line products but thats probably all sh it now that pyramid bought them out along with boss, "pyle's" of sh it, planet sh it audio is also garbage now.
Posted on Jan 06, 2015
I have 2 12
To be on the safe side without further information I would hook the two subs up in series leaving you with an 8 ohm load.
Nov 12, 2012 | Kicker Solo-Baric L7 12'' Car Speaker
Will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 18, 2012 | Lanzar VIBE266 Car Audio Amplifier
Could me and friend install a lanzar max 15" sub into a 2004 honda accord??
Technically speaking, you can install whatever you want into anything you want to install it into. I recommed you doing your research first, because a good amp and sub install job is more than just plugging stuff up. And if your not upgrading to an aftermarker HU, fuggedaboutit!
Feb 22, 2010 | Lanzar (Pair) MAXP104D Max Pro Series...
I have a fifteen inch lanzar max pro p145d and want to put it in an 06 mustang. need to know how much air space i need to make it rumble right
I would go with a sealed because ur trunk is small and sealed would be the smaller box. I recommend 2.0-2.75 cubic ft sealed. for vented would be 3.25-3.50 after woofer displacement. Also I would recommend a reverse wedge meaning the woofer would go on the back side of the box not the angel side because u can slide the box in further saving u a little more room. I'm doing that same box now for the same sub but in a Nissan 2001 sentra. My box when done will be 2.78 cu.ft. After displacement. Sealed. 720 watt rms power acoustick 2ohm stable mono block to get longer life out of my sub.
Dec 18, 2009 | Lanzar OPTI1222D Car Subwoofer
Want to find out the best type of enclosure for 2 lanzar max pro 124d subwoofers
you best type of enclosure will be a sealed enclosure or you can build it with a partition in the middle seperating the 2 subs and port each side.
heres a link that will give you the specs for your sub
http://www.lanzar.com/manuals/MAXP104D-124D-154D.pdf
Sep 07, 2009 | Lanzar (Pair) MAXP104D Max Pro Series...
Amp big enough for speakers
No amp is too big, you can turn the gain down. Anyway in my experience people tend to blow up their subs with underpowered stuff anyway (power spikes from clipping). Your amp is rated at 11000watts max and will probably only put out 500 or 600 watts RMS - RMS by the way is the number you should go by. It indicates the usable output w/ out lots of distortion. On the flipside you can power high wattage subs with an underpowered amp and be just fine. However if you wish to extract the most you will need to match amps and subs. A good example of under powered sub applications is in some of my work- I built a wall of nine 12" subs in a bronco, we competed in a 50 watt class and cleaned house taking first in class. Another would be a 150x2 watt amp driving two 15" CV Strokers (1200 watts each). I was going to compete in that class but they made me move up becuase I was an installer at the time. I was upset at first but after my first try I was able to get about 146db and went on to take first anyway. So if the enclosures are built right you can still use that kind of setup. I hope this was helpfull. If you are concerned with exact wattage ratings the manufactures websites should list them. Good luck.
-Dynami
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Subwoofers were said to be bad
overpowered definitely. when you bridge subs your almost doubling the power. if the subs were set for 2000 then the guy he took them too should have known better or at least turned the power down on the amp.
Mar 13, 2009 | Car Audio & Video
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
Lanzar (MAXP154D) 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker Logo
Top Lanzar Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
