Question about HP Deskjet F4210 All-In-One InkJet Printer
Printer does not print. It goes through the cycle, but no ink transfer to paper. Printer is just connected and new ink.
  • 1,179 Answers
As the ink cartridge is new, the ink need to settle and the ink needs to saturate the system.
You need to use the software that came with you printer and perform a Deep head clean. This will get the ink to come through. Also print many pages until the ink comes through, it may take a while.
If the printer stood without ink for a few days then the ink in the head may have dried and has blocked the ink head of the printer.
To solve this you can use a cotton bud diped into surgical alcohol and apply it to the printer head.
Also be sure to remove the sticker that needs to be removed, it is the sticker that is over the contacts, it is the only sticker to be removed.
Take care!
damnor01
Posted on May 31, 2011
My HP 3550 deskjet will simply not print. It goes through the motions and seems to be printing --but the page is blank or very faint. I have already cleaned and re-calibrated the printer
Check ink-levels -- no ink means no printing.
Run a few more "print-head-cleaning" cycles -- clogged ink-jets cannot spray ink onto the paper.
Jun 20, 2011 | HP DeskJet 3550 InkJet Printer
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
My printer will not print. it goes thru the motion but nothing prints
The ink-jets that spray the ink onto the paper may be clogged; run a few "print-head-cleaning" cycles. Also, check that you've not run out of ink.
Feb 26, 2011 | Dell V313w AllInOne InkJet Printer
Refilled the ink cartridges and now when we ask it to print, it goes through all the steps, but nothing on the paper. Printer is Canon I850.
As much as I hate to say it, you might just try a purchased cartridge to see if there is a problem with the refills. If it doesn't print, then you can keep it as a spare and we can try something else.
If it does print, then might double check the refilled cartridges.
Jul 30, 2009 | Canon Office Equipment & Supplies
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Nothing prints out on paper.
Did you remove the little sticky tabs from each new cartridge? They allow air in, and ink out.
Printing problem - you cannot see the ink on the printed papers
The ink is not flowing from the cartridges to the paper. The reasons for this can be numerous, so we must tackle it step-by-step, which will require a bit of interaction between us.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles (this will waste ink). Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back with a new comment.
Feb 20, 2009 | Epson Stylus C84 InkJet Printer
Epson Stylus C66 inkjet Printer does not print !
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Nov 12, 2008 | Epson Stylus C66 Inkjet Printer
Iron on transfers lexmark x1290
In your printer driver, select the highest dpi setting and the correct paper setting for your type of printer:
Iron-ons are very waxy and the ink may not adhere if not put on thickly. Bellow are some suggested printer settings. For the best results check your printer manual or with your printer's manufacture. CANON: T-shirt transfers.
EPSON: High quality glossy paper or special coated paper, depending on the model.
HEWLETT-PACKARD: High quality glossy paper.
Lexmark: T-shirt transfers.
IMPORTANT: Then set the paper thickness lever on your printer for standard paper. You want the ink nozzles very close to the page.
Jul 23, 2008 | Lexmark X1290 All-In-One InkJet Printer
HP Deskjet F4210 All-In-One InkJet Printer Logo
Ekse
Thomas F. Schneider
