Question about White Sewing 2037 Mechanical Sewing Machine
I plugged in my machine after it had been sitting idle for about a year. I have power and can hear the motor turning, but the needle doesn't move. It acts like a 'clutch' has been disengaged. Is there a way to disengage the drive train; for instance when you are filling a bunch of bobbins? I seem to remember a machine that you could do this with but it masy be another. There is no troubleshooting guide in the owner's manual. Can you help?
Posted by mnteverly on
Tally Girl
  • White Sewing Master
  • 1,134 Answers
Does sound like machine is in bobbin winding mode. The clutch may be disengaged by an inner wheel on the flywheel, flicking the bobbin spindle over or a button.
Best thing is to check the manual for your machine as they all vary. Go to http://www.singerco.com/accessories/instruction-manuals/search
then type in the model number with a w in front and click search.
The White and Singer manuals are listed here and many are free downloads as pdfs.
I hope this helps you out.
Posted on May 30, 2011
Is the motor in my kenmore sewing machine bad?
will the motor run if you turn it by hand when the power is on
Apr 02, 2014 | Sewing Machines
My daughter's brand new, right out of the box Janome 2212 machine is not working. The foot pedal is not engaging the motor so the needle doesn't move up and down. The wheel is pushed in as it
Sorry, but gotta ask is it plugged in and turned on? Check before you answer. (I ask this because it happened to me, set up, ready to go, and no power. After an hour and the machine was in pieces, My son asked if i plugged it in and I snapped "YES, DUH" not seeing him twirling he plug in his hand...he informed me that you must be 10% smarter than anything you operate or eat....at which point he was happy to inform me, the machine was 11% smarter. If it is plugged in and turned on, is the plug to the foot pedal plugged all the way in? Is the machine on? If you get zero reaction, no movement or sound of any kind, the foot pedal my be faulty, it can happen. Take it back to the dealer and they should replace the entire machine or the foot pedal. Good luck and happy sewing.
Jan 10, 2013 | Janome 2212 Sewing Machine
My pfaff 1222e isn't working the motor runs but the needle doesn't move ~ the knob at the end of the machine won't turn at all
Check for thread jams... hopefully that's the problem and not a bent shaft in the thing.
Nov 28, 2012 | Sewing Machines
The motor is running but the needle doesn't go up and down
if your foot pedal is connected correctly,, it's possible that a part in the machine
is damaged,,it would be a good idea to have the machine serviced to see
what the problem is for sure.
Jun 02, 2012 | Sewing Machines
Singer 2662 Needle doesn't move
when was the last time the machine was serviced?
Apr 11, 2012 | Sewing Machines
How do I change the needle on my overlocker
TURN OFF POWER! UNPLUG FROM WALL OUTLET! HOLD needle so it doesn't slip down into needle hole and turn screw towards you to loosen it. You must raise presser foot and push new needle UP flat side BACK as far up a's that needle will go! Tighten screw. Needle on left side same length a's one on right but will just appear to be higher then the one on right. Not to worry! It's supposed to look this way when needles correctly positioned! Jimmy
Apr 04, 2012 | Sewing Machines
It was working fine. Then stopped. When you depress the pedal the motor idles but the needle doesn't go up and down
it's possible that the foot pedal has gone out
check to make sure the power cord in inserted into the machine correctly & also the foot pedal
Apr 02, 2012 | Sewing Machines
Brocken both needles and power went off the machine
I guessing that from what you say broken both needles you are talking about a serger, unless you are using twin needles in a sewing machine
if the power has gone off, have you tried turning off the machine & turning it back on, if that doesn't work then it's possible that the power cord may have gone out, or the on & off switch may have gone out.
the only things broken needles will do is knock the machine out of time or jam it up
Mar 27, 2012 | Sewing Machines
My bernina E65 will not work,Help
since the machine has been sitting up for close to 2 years it needs to be serviced also.
when a machine sit up the grease & oil can become yuckie & machine will not respond good & sometime not respond at all.
it's also possible that the machine can have a loose or broken part
Mar 19, 2012 | Bernina Sewing Machines
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
White Sewing 2037 Mechanical Sewing Machine Logo
136 people viewed this question
Top White Sewing Sewing Machines Experts
Colin Stickland
Colin Stickland
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
