Question about Kitchen Ranges
Hello, I have a PDl790S Oven which has the separate grill at the bottom, it has two doors. I have removed the grill element and have lost my paper that tells me which wire goes where. can you help with this , one side of the element has two connectors and thats where I am stuck, thanks very much.
Posted by adrdia on
1 Related Answer
Anonymous
SOURCE: Rangemaster Toledo 110 oven/Grill element
How easy is it to fit a new grill element. The element on the left hand side of the grill is not working so I need to replace this. I'm just wondering if this is easy to do myself or do I need an
electrician
Regards
Sandra
Posted on Jan 17, 2008
How to install Hotpoint Upper Oven Twin Grill Element
ISOLATE POWER. take rear panel off.
take door off.
remove element securing bolts/screws.
remove terminals (pay attention where they go, or photo, or mark them)
remove element and replace.
reconnect, resecure, replace rear panel, replace door
> go to cafe for brunch.
Oct 17, 2013 | Hotpoint Indesit Bd32 Dy46 Ew74 2660watt...
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
Element won't heat on oven setting but does on grill setting any ideas on problem
The element for the oven is separate from the grill element. As you haven't specified your oven brand or model, I can't say that with 100% certainty, but every oven I ever seen has separate elements for grill and oven.
It's most likely that your oven element is burnt out. To check this, you need to get access to the oven element and (with the power off) test for continuity/resistance across the live and neutral terminals of the element. You'll need an Ohm meter to do this.
If your oven element checks out, the next things to check are the oven switch, thermostat and the wiring from the oven switch to the element.
I'd guess your element is burnt out. Common problem, especially if you've had the oven a while.
Please rate my solution if you find this helpful. Thanks.
Oct 16, 2010 | Ovens
Grill is not working
Is The small amount of heat you are getting coming from the bottom element in the top oven or is half the top Grill element working.To start with you have a double grill element and either the whole element has gone or just half the element.This is controlled by a selector switch which could be at fault or the Thermostat that controls the temperature.
Hope this helps.
Jul 07, 2010 | Electrolux Insight EKC6049X Stainless...
How to replace the grill element in a Stoves 720EF double oven?
1) Isolate the unit by turning the power off at the main switch.
2) Remove appliance from housing unit.
a) When handling the appliance care should be taken to ensure the outer frame trim is not damaged.
b) The appliance is secured into the housing unit by 2 screws through the top corners of the front frame, open the doors and unscrew the 2 corner screws.
c) Grasp the bottom of the frame, pull forward and out onto a suitable surface.
3) Unscrew the top and rear panel securing screws and lift the panels clear.
4) From the rear of the appliance, pull off the 4 (top) grill element leads and the earth lead.
5) From inside the oven unscrew the 2 screws from the grill mounting plate.
The above is from the Handbook. I assume from point 5 the element is then free to be removed. reverse the procedure to fit the new element.
If you want a copy of the Handbook, then I will need an email address for you.
Mar 11, 2010 | Stoves 720EF Electric Double Oven
Cleaning above the grill element
I would not advise you to remove the element unless you feel competent to do so.
Best thing to do is to put the grill full on and let all the fat and grease burn itself off.
you will not hurt anything by doing this.
Make sure you have the griil door open and your house door.
Plz rate my solution.
thanks.
Dec 18, 2008 | Candy FP855 Electric Single Oven
Instruction manual
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Sep 11, 2008 | Ovens
Grill, top oven and all lights not working after grill element blows
Brinkmann has a terrible customer service dept. You are better off with a new unit.
Jul 30, 2008 | Grilling
Fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
May 04, 2007 | Bosch HBL 5032 Electric Single Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
