Question about Casio FX-300MS Calculator
How do I calculate the mod function in my casio fx 100ms model
Posted by vaicha_oracl on
  • Anonymous Mar 19, 2014
    How to integrate with definate integrals in casio fx 100ms
nathane35
    Sniper:
  • 113 Answers
It seemed there is no Modulo function in fx-100MS. But Mod is just the remainder of a division operator.
So if you have A mod B = C, divide A by B, subract the remaining whole number, and multiply it by B to get C.
Example:
7 mod 4 = 3
In the Calculator:
7 / 4 = 1.75, then 1.75 - 1 = 0.75. Then 0.75 x 4 = 3
Posted on Jun 24, 2011
  • rrtiwari1987
    rrtiwari1987 Feb 10, 2012
    In the Calculator : 7/4=1.75 then press a b/c button(Fraction Button).
    1 L 3 L 4 , The middle portion i.e. 3 will be the Result of 7 mod 4
  • Mayank
    Mayank Nov 25, 2013
    ye trick sahi nhi h plz solve 6/4=1.5 then press a b/c button(Fraction Button).1L1L2,The middle portion i.e. 1 will be the Result of 6 mod 4 But 6 mod 4 =2 so this is wrong.trick and it's can't use to maximum values like 4^454 mod 323...
Nivethitha V Somu (Nivi)
    New Friend:
Hey that solution too works for large numbers.... Thank you
For e.g
1) 130 mod 26
130 / 26 = 5
5 - 5 = 0
0 * 5 = 0
2) 398 mod 26
398 / 26 = 15.30
15.30 - 15 = 0.30
0.30 * 26 = 7.8 = 8
Posted on Dec 30, 2014
Shifna kadz
    New Friend:
ASKING FOR LARGE NUMBERS
Posted on Nov 25, 2014
5= 4x+27 / 3.....Can this equation be solved on a casio plus?
Assuming you meant "5 = (4x +27) * 3^-1", if you enter the values as "((5 * 3) - 27)/4", I'm sure the calculator can handle that.
Sep 21, 2015 | Casio Office Equipment & Supplies
I cant find my Antilog button on my Casio fx-100MS
The common antilog is the shifted function of the "log" button (marked 10-superscript-x) and the natural antilog is the shifted function of the "ln" button (marked e-superscript-x). The log and ln buttons are both on the third row of the keyboard.
Aug 25, 2012 | Casio Office Equipment & Supplies
How to calculate modulus of function using fx-9750GII ?
To enter the MOD( function on the command line:
  1. Press Menu
  2. Press 1 or select icon Run>Mat.
  3. In Run>Mat screen, press the OPTN key.
  4. Press F6> to pan through the other options.
  5. Select F4:Num and press F6:> to get other tabs
  6. Press F4:MOD
Example: MOD(278,9)=8
An alternative way is to use the Catalog.
  1. Press [Shift][4] (catalog)
  2. Press [ALPHA][7] to jump to letter M
  3. Scroll down from there to reach the MOD( command.
Jul 11, 2012 | Casio FX-9750GPlus Calculator
I need to calcualte 4587 mod 8 how do i do this on the casio fx-115MS? (there's no 'mod' button) Many thanks
The lack of a mod function makes this more than a bit painful. Here's one way:
Press MODE 4 to go into BASE-N (integer) mode. If the display doesn't read "Dec", press the x^2 key. Now calculate 4587-4587/8*8 (press 4 5 8 7 - 4 5 8 7 / 8 * 8 =, where * is the multiply and / is the divide).
You can calculate other mod problems the same way. a mod b is a-a/b*b.
Press MODE 1 to return to your previously scheduled calculations.
May 11, 2011 | Casio FX-115MS Plus Calculator
How to calculate 24124 mod 19937 in casio fx-991Ms calculator
The MOD function simply returns the remainder that is left over after dividing the two numbers.
In this case, its possible to see quite easily that only 1×19937 can be taken from 24124 before the remainder is less than 19937. The MOD function is therefore the same as 24124 - 19937 = 4187.
In cases that are less obvious, do the division, ie 24124 ÷ 19937 = 1.210011536[34]
[The last two digits are hidden on the display but still used in subsequent calculations].
Then obtain the fractional part by subtracting 1 to give 0.210011536[34]. Then multiply the answer by 19937 to give 4187. Assuming that you haven't cleared the screen between each section of the calculation, the screen will show "Ans×19937 [=] 4187".
May 10, 2010 | Casio FX-115MS Plus Calculator
How to get mod on it
If you are thinkink of the modulo function, usually shortened to mod(, I am sorry to say it but that function does not exist on the calculator.
However, there is MODE button that one uses to set the operation mode of the calculator.
You have three principal mode setting
COMP: the general computational mode
SD: a statistics mode to calculate Standard Deviations
REG: to perform REGression analyses on statitical data.
Once you have chosen the preferred calculator mode (COMP, SD, or REG) other choices (dependent on the main calculator mode) will be available.
May 03, 2010 | Casio fx-300ES Calculator
I have scientific calculator fx-100ms & i dont know haw does it work please show me its manual
What happened to the manual that came bundled with the calculator?
The following link will take ypu to the casio web site where you can download the manual you need.
http://support.casio.com/pdf/004/fx115MS_991MS_E.pdf
Hope it helps
Aug 26, 2009 | Casio Office Equipment & Supplies
M mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
Jun 29, 2009 | Casio FX-115MS Plus Calculator
Casio FX-300MS Calculator Logo
8,718 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
