Question about Sherwood RX-5502 Receiver
Hello, I have a Sherwood RX-5502 and currently have a pair of 8Ohm speakers hooked up to the SPEAKER A terminals. Can I hook up a pair of 4Ohm speakers to the SPEAKER B terminals without issue from the receiver?
Posted by panizzon4 on
David Dunn
    Brigadier General:
  • 8,546 Answers
The statement on page 7 might allow enough wiggle room for a single pair of 4-ohm speakers used alone. Procede with caution and don't try to blow the walls down with them. Monitor for excessive heat or strain and if it clips or self-protects back off.
http://www.sherwoodusa.com/pdf/RX-5502(A).pdf
Posted on May 30, 2011
I do not know how to hook up the speakers to the back of a sherwood RX-5502
You untighten those connections, i mean really untighten them then you will see that there is a whole that you can feed your wires into once you have unscrewed those inputs far enough.
May 26, 2012 | Sherwood RX-5502 Receiver
Unable to connect speaker wires to back of Sherwood 5502 receiver (no way to get them toi stay in)
If you unscrew the red and black knobs a few turns you will expose a small hole that is drilled through each post. Insert the twisted bare wire end into the appropriate hole and tighten the black or red knob to secure it.
Or get connectors as in this article...
http://www.crutchfield.com/S-gtpAzL9W1OZ/learn/learningcenter/home/speakers_wire.html
Jun 07, 2011 | Sherwood RX-5502 Receiver
I have a sherwood RX 4109.....can i hook a pair of 6 ohm speakers and then a powered sub?
By design, yes for one pair of 6-ohm speakers used at a time; depends on the sub for the second BUT there is no way to control its volume at the Sherwood.
Mar 25, 2011 | Sherwood RX-4109
I would like to connect my powered subwoofer (Atlantic Technology model 212 SB) to my Sherwood RX5502 receiver. Unfortunately, the receiver has no subwoofer outputs, only speaker outputs, and the...
Cables between sources and compatible units rarely need to be physically modified.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RX-5502-Receivers-manual/id/3124dj384/t/2/
http://www.retrevo.com/support/Atlantic-Technology-212-SB-Subwoofers-manual/id/866dj197/t/2/
Splicing headphone outputs designed for nominal 8-ohm impedance speakers to a 47K-ohm (typical) RCA load is not a good idea but it might work on the Sherwood because this receiver does not automatically silence your other speakers when the headphone jack is installed.
There is NO other volume-controlled output to choose. Try it.
Mar 25, 2011 | Sherwood RX-5502 Receiver
Sherwood RX-5502 receiver - get no sound.. checked polarity - OK... replaced speaker wire - OK... checked speakers on another device - OK.... tried phono and tuner and cd player - no sound with any........
After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
There may aIso incorrect selection of the input source. Select the correct input source.
If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
Thanks for using Fixya.
Jul 11, 2010 | Sherwood RX-5502 Receiver
CORRECT CONNECTION TO AMP BEING A FOUR TERMINAL SPEAKER
Hello i_starling,
The Kicker L7's come in either 2ohm or 4ohm dual voice coil (DVC) versions.
Whatever amp they are connected to, you need to know both the impedance of your L7's and the impedance of your amp. The L7's dual voice coils can be wired to provide a total of four different loads:
2ohm coils in parallel = 1ohm load
2ohm coils in series = 4ohm load
4ohm coils in parallel = 2ohm load
4ohm coils in series = 8ohm load
Your best connection would be the one that results in a final impedance load that is supported by the amp.
Hope this helps.
May 01, 2009 | Car Audio & Video
Can i kook up 4ohm dvc sub to a kac-x810d amp?
No, the sub is dual 4ohms...meaning if you parallel the positive speaker terminals and the negative speaker terminals you will have a 2ohm sub. Conversely, if you series the pos and neg you will have an 8ohm sub. if you wirte to just one set of terminals on the sub you will have a 4ohm sub.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Apr 12, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
Behringer ep2500 amplifier
Yes you can,,,,,BUT the output labelling on the AMP will tell you where you can connect the 4ohms or the 8ohms....please read these labels and connect the 4ohm speakers to the 4ohm terminals, and the 8ohms to the 8ohms terminals...
If you intend to connect the 4ohm and the 8ohm speakers in parallel then the output impedance terminals you use should be the 4ohm ones.
If there is no labelling showing any 4ohm output terminals then its best if you dont use the 4ohm speakers at all....just connect the 8ohm to the 8ohm terminals...you dont mention any crossover networks inside the speaker boxes or if you have tweeter speakers... so just stick to the basics above at present....
Cheers From YUBEUT
Oct 20, 2007 | Sunfire Cinema Grand Signature 400 seven...
Aftermarket 6 x 9's
What type of car is it? You can purchase speaker harnesses at any car audio shop that will allow you to snap into the factory plugs. Also, beware if your system was designed for 8 ohm speakers - using 4ohm speakers instead could cause some problems. Most aftermarket stereos are designed for 4ohm speakers, but some factory stereos designed for 8ohms could be damaged if you give them a smaller ohm load.
Sep 15, 2007 | Car Audio & Video
Sherwood RX-5502 Receiver Logo
287 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rhodesworks
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
