Ok with the power button turned off press and hold the power button you will here one beep and then two beeps and then release and look at your tv and there you go.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
no problem glad I could help a fellow gamer!
thanks men. i will try this tommorow. I hope that will help.
Thanks again for the fast solution.
no problem ya sony doesn't have a auto detect and reset for the audio/video cables so it needs to be reset via that way the only other way you could do it is hook it up via hdmi again and then go into the display settings and set it over to A/V cables
Hey like the person above mine turns on you can hear it but can't see it is there any thang I can do
Try the steps they did it should help and get your machine working again properly in just a few mins.
Pls sir am a tech am working on a ps3 that don't show on tv ,I have try to hold the pawer butten but when I hold it ,it will only beep once and off back pls help me sir am from nigeria
