Question about Vivitar DVR 850W Flash Media Camcorder
I cant turn on the flash on the camera. i press left arrow when in camera mode but the flash wont turn on. it toggles through other stuff but the flash wont turn on. it shows the lightning flash symbol with a slash through it...'( not happy with this camcorder at all...when i need to get a shot its not avail..
Posted by iwait4uinpr on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
The flash doesn't work for videos, only for still photos. If you need a light for videos then you'll need a separate light.
Posted on Feb 18, 2012
  • iamgizzmoid
    iamgizzmoid Apr 17, 2013
    Why don't a**holes like you read a person's question before giving such a stupid answer. iwait4uinpr wants to know how to turn on the flash for taking pictures, not making videos. I am also trying to find out how to turn on the flash for photos, but people like you just waist everyone's time.
I have an auto flash, but it's not flashing. Do I need to somehow turn this function on? If so, where is it?
Follow below mentioned steps to turn flash on:-
  • Rotate MODE DIAL to any one of them Auto, program, portrait, landscape, sport or night mode.
  • Press POWER button to turn power ON.
  • Press Navigation button (left arrow button), Flash mode change each time button is pressed. you can use UP and Down Arrow button to change settings. Set it to FLASH ON.
  • Press OK to confirm settings.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
How do you turn the flash on
Using the Flash
The flash is designed to function automatically when lighting conditions permit the use of flash.
The camera has 3 flash modes: Off, Auto , and Always On. You can take an image using
a desired flash mode to suit your circumstances. The flash's effective range is
35.4” ~ 59.1”(0.9m~1.5m) (in Normal mode).
The flash is disabled if the camera is set to Macro mode.
1. Press the Power button to turn the camera on.
2. Toggle until your desired flash mode appears on the LCD display.
3. Compose your scene and press the SHUTTER button
to capture your image.
Flash button is the one like an arrow pointing downwards. (not a straight arrow) Usually located beside Disp, OK, Menu.
Flashes turn off and on in the LCD. beep sound
Hello!
Please consider the troubleshooting given below:
(a) Remove the Battery from the Camera then press and hold the power button for 30 seconds.
(b) Reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery pack is fully charged.
(c) Next, try resetting the Camera to the original factory settings if the menu options are accessible on the Camera.
Perform the steps given below to reset the Camera to the original factory settings:
(i) Press the Menu button on the Camera to access the menu options.
(ii) Press the right arrow on the control button to select (Setup) setting, then press the right arrow again.
(iii) Press up/down/left/right arrow to select the Setup 1option.
(iv) Next, select the Initialize Option and select OK.
Performing the above mentioned steps will reset the Camera to the original factory settings.
If the issue persists even after performing the above mentioned steps then service will be required.
2helpful
Canon IXUS 80IS - I can't turn the flash on
When this camera is in "Auto" mode the only flash functions available are Auto or Flash Off - in order to get the option of "Flash On" for all pictures you have to put the camera in "Manual" mode - to do this:
-Set the mode switch to the camera icon
-Press the "Func./Set" button
-Use the left or right arrow keys to set it to Manual mode (its icon looks like half a camera with the letter M beside it)
-Press the "Func./Set" button again to save your mode change.
Now when you press the flash button and cycle through the choices there will also be a "Flash On" option.
4helpful
Lost instruction booklet
On the back of your camera is a button that has a squiggly arrow - that is the flash mode setting button. Toggle through that button to set the flash to off. Flash off is a squiggly arrow in a circle symbol.
1helpful
Hello i want to turn the auto flash off
Press the up arrow on the back of the camera - that seems to be the flash mode setting - select which flash mode you want - you have to hit the down arrow once to see the flash off option which is a picture of a flash symbol in a circle. Then press ok. The flash should now not fire.
Desativate flash
I do not exactly know the menu of your camera, but usually in the case of Olympus cameras there is the left button on the cross button that exists at the back. By pressing it once while you are in the "Shot" mode, not in "Play" mode you activate it. If you press again you de-activate it. Therefore, as you can understand the operation is toggled by pressing the left button on the cross. You also have an icon which everytime you press the button it "tells" you if the Flash is ON or OFF.
Flash
I do not exactly know the menu of your photo camera, but on my Olympus there is the left button on the cross button that exists at the back of the camera. By pressing it once while you are in the "Shot" mode, not in "Play" mode you activate it. If you press again you de-activate it. Therefore, as you can understand the operation is toggled by pressing the left button on the cross. You also have an icon which everytime you press the button it "tells" you if the Flash is ON or OFF.
How to use auto timer
1. Turn on the camera in picture taking mode.
2. Now press the left arrow button.
3. Select the timer duration with the up and down arrow buttons, then press MENU SET.
4. Aim the camera, focus and press the shutter button. You now will have either 10 seconds or 2 seconds before the camera takes the picture.
SLIDESHOW function
You can play the images in your camera on a TV or save them to videotape by connecting the camera with the bundled Audio/Video cable. Power up the camera in the PLAYBACK Mode, press the OK/MENU button to open the menu and using the arrow keys toggle up to begin the SLIDESHOW. You can even change the playback format in the MODE MENU. Press the OK/MENU button and using the right arrow key select the MODE MENU. Toggle down to SETUP, toggle right to enter the SETUP MENU and toggle up once to PLAYBACK SETUP. When you toggle right you will be offered four playback options: NORMAL, SLIDE, FADER and ZOOM. When selected you will get the following effects: NORMAL - Each image instantaneously replaces the previous image. SLIDE - The images are sequenced by sliding from right to left. FADER - The images are sequenced via a lap dissolve. ZOOM - The images are sequenced by zooming in to black and zooming out from black.
Vivitar DVR 850W Flash Media Camcorder Logo
Top Vivitar Video Cameras Experts
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
