Hi! I purchased this auto wine cooler and someone removed the charger and foil cutter from the box. How do I purchase the charger and foil cutter and how much would it be for each one? Box says WC-15 auto wine opener with charge and storage stand by kitchen selectives. Bottom of box says: sku # 6 5577200249 5 distributed by select brands, Inc Lenexa, KS. www.selectbrands.com Made in China. Up to 15 bottles per charge. I would appreciate the information. Thanks! Arlene
Posted by crystal66 on
  • Anonymous Mar 05, 2009
    I just purchased my auto wine opener also, and I was just missing the charger. However, it looks like the cutter is broken. Isn't this odd. I can't take it back because I purchased it at a donation store.
    All other parts look as though it has not been used.
    Susan [email protected] 3-4-2009
5 Related Answers
Anonymous
  • 34 Answers
SOURCE: D to A Box, with broadband passthrough no remote necessary
not sure
Posted on May 22, 2008
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: Wine Cooler Temperture Regulation
Replace the circuit board . Please Rate This !!!! Thank You!!
Posted on Jun 08, 2008
Anonymous
SOURCE: samsung black jack cell phone
There should be layouts available (i.e. AT&T Default, Large Font, Windows Simple, Windows Default....etc.). It changes the way the icons are arranged on the home screen.
Posted on Jul 30, 2008
Anonymous
  • 3 Answers
you should be able to just scroll left through the menu with your directional button on your phone. i might be misunderstanding you, but i dont think you can type anything in there...just scroll through the various options like AT&T Default, AT&T Windows Basic, etc.
Posted on Aug 07, 2008
Anonymous
SOURCE: I just purchased a Sakar
I feel your pain. Go to their web site and download a readable manual http://images.google.com/imgres?imgurl=http://www.sakar.com/images/resources/thumbs/12690%2520black.jpg&imgrefurl=http://www.sakar.com/p-169.aspx%3Fcategoryid%3D155&usg=__UCOoniXB9VJe9zn80S4X1J8mj7o=&h=120&w=104&sz=9&hl=en&start=8&um=1&tbnid=5j97XYF3RmFbdM:&tbnh=88&tbnw=76&prev=/images%3Fq%3Dsakar%2Bdigital%2Bphoto%2Bframe%2B12490%26um%3D1%26hl%3Den%26rlz%3D1T4GGLL_enUS305US305
The key is to hit the send photos button in the upper left hand corner of the main page. that will open up the photo viewer. Once there the instrutions actually make sense. going to select Photos and opening active image express will not down load the pictures, you have to get to the photo viewer v2.3. the manual is correct you just have to read if very carfully.
Good luck
Posted on Dec 31, 2008
Cabernet 500ml carton
First off 500ml seems like quite a small amount of wine as the traditional bottle is 750ml, but okay. If the foil seal was punctured before your purchase there is an easy way to tell if the wine has gone bad. Pour about a shot glass worth of it into a typical wine glass and swirl it around in the glass for about 10 seconds. Smell it while it's still swirling and if you pick up any instant sour notes then your wine most likely has started to sherry. Not that this will hurt you in any way, but it makes the wine less enjoyable. If someone opened it before and allowed air into the wine that's all it takes. My advice, stick to boxed wines as they are engineered not to allow air into the wine at all and can keep for a very long time if refrigerated. Better yet, grab a bottle of some of the good stuff and drink within 2-3 days of opening, keep refrigerated.
Jun 29, 2013 | SONOMA VENDANGE WINERY Wine & Spirits
Why should I buy a thermoelectric wine cooler as opposed to a compressor model?
There are many reasons to purchase a thermoelectric cooler including, but not limited to, being quiet and eco-friendly. Personally, I prefer thermoelectric coolers because they don't vibrate. The vibration of a compressor cooling system can cause the sediments in the wine to be disturbed and affect the flavor/taste of the wine.
Jul 31, 2012 | Furniture
I purchased replacement screens and cutters in December. One of the screens now will not stay on. Vibration from the motor causes it to pop off the shaver.
The problem is likely cause by a buildup of whisker particles keeping it from locking into place.
The first thing I suggest is to remove the foils from the frame that they go into. Once removed, thoroughly clean the foil frame and foils and then reinstall them.
If this doesnt solve your problem, there may be a defect with the screens or wear to the frame that the foils snap into. You will have to determing which you need to replace.
If you need to replace the foils, you can purchase replacements at shaveroutlet.com. See link below.
http://shaveroutlet.com/remington-sp96-smart-system-series-foil-and-cutter-set-p-237.html
Feb 13, 2010 | Remington MS-5100 Electric Shaver
Hi I cannot hear my thermostat in my wine cooler click when I turn it up or down. Do you think it is the thermostat needs replacing. If so where can I get a replacement?
If nothing is running and the lights are on then you need to replace the conntrol. You can visit U-line website to find out where to purchase the part, www.u-line.com and under customer service you will see parts locator.
Oct 02, 2009 | U-Line 2075WC Wine Cooler
Want to purchase relay. Can't find part locally.
The best thing to do is go to your local appliance parts warehouse and match up the relay with what they have in stock.
Be sure to briung all relevant info you might have on the unit.
That way you can ask for the RF-5600-01 to compare it before purchasing. Thats exatly what a service tech would do if you called one, only they will charge you 50 to 100 bucks to do it.
Aug 25, 2009 | Haier HVFM20ABB Wine Cooler
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Returning a Danby Winecooler
This unit was purchased in West Hollywood, CA on LaBrea.
May 30, 2008 | Danby DWC283BLS Wine Cooler
Computers & Internet Logo
Ekse
Marvin
Marvin
