Question about Lexmark X2650 All-In-One InkJet Printer
Hi my lexmark x2650 keeps flashing error code ec5, how do i correct this?
  • Official Brand Answer
  • 3,344 Answers
The EC5 error code indicates a short has been detected in one of your cartridges. Open the printer and remove both cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover and check for any errors. Open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the error to pop up. Or you can try to insert a different known working cartridge to determine if the other is faulty.
Posted on Jun 01, 2011
  • roberto ferranti Jul 11, 2013
    when i put only one cartridge no error if i put both error ec5
  • Dennis Ford Sep 18, 2013
    Tried with no problems solved. Junk Printer
Lexmark service centre
EC5 means short test detected: short circuit in printhead. The cartridge needs to be replaced.
Oct 29, 2012 | Lexmark X2600 All-In-One InkJet Printer
My screen on the printer is flashing e c 7
Charles,
Found a list of error codes at the link below.
Error Codes
Lexmark Support for your printer below
Hope this helps.
Mar 27, 2011 | Lexmark X2650 All-In-One InkJet Printer
I do not have any instructions and want to photo copy.
Go to link below, you should be able to download your printer manual from it. Lexmark X2650 All-In-One Inkjet Printer User Manual Free Download User Manual: Lexmark X2650 All-In-One Inkjet Printer - Service Manuals, User Guide, Reviews, Instruction Manuals and Owner's Manual.
www.generalmanual.com/Printers/Lexmark-X2650-All-In-One-Inkjet-Printer.htm ·
Nov 04, 2010 | Lexmark X2650 All-In-One InkJet Printer
I dont have a disc and want to download to be able to print I do own a x2650 printer but did not get a disc where do I go to down load the program
The latest drivers for your device and operating system can
be found here-
http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_UK&segment=DOWNLOAD
download, install and restart your computer.
If the problem persists reply with any error messages or
additional information.
//javaftper
Jul 31, 2010 | Lexmark X2650 All-In-One InkJet Printer
Printer error flashing 1 then E then C, after changing printer cartridge on lexmark x650, which installed correctly.
Try turning of printer, disconnect from power, Now removing ALL Ink, clean both the cartridge, and where they go, make sure is real clean. Now replace them. Then reconnect Power, & turn on. Hopefully this will have reset the printer. If NOT then your printer for what ever reason has developed a fault, OR that new cartridge is incompatible for whatever reason, perhaps a refilled, or counterfeit one?
Mar 24, 2010 | Lexmark X2650 All-In-One InkJet Printer
Don't know how to make pics smaller on the scanner of the lexmark x2650
Hi
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Lexmark-X2600-X2630-X2650-X2690Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Mar 07, 2010 | Lexmark X2650 All-In-One InkJet Printer
X2650. False Paper Jam indicator.
There are a few options for you. You can power it completely off for a few moments to see if that clears the error. During that time I would recommend using a can of air to spray out the inside of the printer. The sensors can get dust on them and make it appear that you have a paper jam. Also if there is a small piece somehwere the pressurized air will hopefully dislodge it.
Good Luck!
Oct 30, 2009 | Lexmark X2650 All-In-One InkJet Printer
Problem with cartriges
EC5 = Print Head Short. Short test detected short circuit in printhead. Fix is to replace print cartridge(s).
Sounds like one or both of your new cartridges are defective and need to be returned to where you purchased them.
Mar 02, 2009 | Lexmark X2600 InkJet Printer
Error on newly installed printer.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Lexmark X2650 All-In-One InkJet Printer
Lexmark X2650 All-In-One InkJet Printer Logo
6,306 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
