Question about Kohler Home
Kohler Steam Shower. Getting ERROR MESSAGE 5. Need to know how to fix the problem.
Posted by jlhmo4 on
REYNALDO DE LA PENA
    New Friend:
  • 41 Answers
Check the steam outlet to make sure is properly tight this can cause a false ERR 5
ERR5 comes up when water flow to the unit is blocked or debris has gotten in the unit and clogged check filters,test the water flow
Posted on May 30, 2011
Error 5
-error 5 is caused by the back pressure of the steam head if water supply to the generator is sufficient and the steam output pipe to the steam head is plumbed according to the manual.
-Kohler recommends to modify the steam head to remove the wax motor, spring and snap ring in the housing. Call Kohler for instructions.
Jan 15, 2011 | Vibrant KOHLER Steam generator control kit...
I have a Kohler K-7 steam generator/shower and after using it just fine, water now just pours out of the steam outlet - even if the unit is turned off at the control head. I have had to close the inlet...
There is a float valve interior of the steam generator that supplies water to the generator unit. There are no parts available for that unit, and Kohler was useless re: repair. I have the same unit and mine is doing the same thing. I took it apart and there is a washer worth about a nickel that is inside the unit. I flipped the washer over in mine and it worked for about a week....then back to the same problem.
Dec 05, 2009 | Kohler K-1698-G Brushed Chrome Tandem...
Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Sep 27, 2009 | Kohler Fairfax Single Control Lavatory...
Error code Prr on Mr. Steam control unit. Steam generator starts for about 10 seconds, but no steam comes out and error code "Prr" shows on control unit. Any insights?
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Sep 15, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
The kohler steam unit keeps shutting down prematurely
Since I don't have your model number for this, I am going to attempt an answer for you. Yes, there could be a filter but not always. Sometimes, the sensor on these units can become stuck closed and is sending a false error. Does the unit seem to be working? If it is, then it probably is a false signal. If not, the there could be debris that has gotten into the water lines. Either way, if the unit is new, then it will be under some sort of warranty. I would contact either Kohler or an authorized service rep.
Apr 05, 2009 | Home
Kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Mar 14, 2009 | Kohler Plumbing
Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Jan 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Home Logo
829 people viewed this question
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
