Question about Sony Cyber-shot DSC-W55 Digital Camera
Cybershot won't take pictures
I have a sony cybershot, model DSC-W55. when i press the power on button, the camera does not turn on as it usualy does. instead, i get a black screen with the word Access on it. (also, when i turn the camera on, the lenses keep going in and out more frequently than before.) so the screen Access screen is just there right now, but when i click buttons like menu or display it makes beeping noises and it says 'press power on and off again '. i can still view the pictures i've taken but can't seem to TAKE the pictures.. HELP ME PLS! i've had this camera for only 3 months :(
5 Related Answers
Anonymous
SOURCE: format error c:13:01 showing on
no it was nt helpfull in our case. as we have remover external memory card. reformated the apparatus & started again.
now we r using only its internal memory. it means problem was with external memmory card.
Good Luck.
Posted on Jun 26, 2008
Anonymous
SOURCE: driver for sony cybershot DSC-W55
they don't have the drivers there...
Posted on Jul 18, 2008
Anonymous
SOURCE: Cybershot camera not reading the memory stick
Have you tried reformatting your memory card itself?
Posted on Jul 21, 2008
Anonymous
  • 21 Answers
SOURCE: i have a sony cybershot,
You can try contacting Sony - maybe through online chat if its available for free. From what you have described, it sounds like a hardware failure. Contact Sony, and if it is a hardware failure, they will replace it for free. Or, if you have bought it from a big retailer (i.e. bestbuy, futureshop, etc.), you can try asking them for an exchange for a new camera. They will send it the old, broken camera into Sony for you and replace the camera with a new one. Just make sure to take out your memory card first (don't wanna lost all those pictures in there).
Hope this helps,
Eric
Posted on Aug 17, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: My Sony Cybershot DSC W55
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Posted on Jan 28, 2009
My Sony cybershot dsc-w55 won't take pictures! I
Your lens is stuck due to either being banged or bumped or there is dirt/grit inside the lens gears. The lens needs to be replaced, but buying a brand new lens is out of the question. Sony will charge $125 just for the lens assembly, it's crazy.
A refurb lens can be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Sony Cameras
Camera FELL AND WON
the part which comes out when the power is on might have got stuck .. try repairing it .
Apr 09, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Problem when starting up sony cybershot W55.
Your problem is mainly like above.
If you want to check the other troubleshootings please download the user manual of Sony Cyber-Shot DSC-W55
Feb 22, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
I need another copy of the full manual Sony DSC w55
hi
you can download the manual at the folowing URL
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSC-W55&region_id=1
happy clicking
pls rate if this was any help
Jul 14, 2009 | Sony DSC-W55 Digital Camera
Sony cybershot dsc - w55
the part which comes out when the power is on might have got stuck .. there may be some dust particles. just blow over it or vaccum it..
Dec 26, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
I have a sony cybershot, model DSC-W55. when i press the power on button, the camera does not turn on as it usualy does. instead, i get a black screen with the word Access on it. (also, when i turn the...
Hope this helps,
Eric
Aug 17, 2008 | Sony Cameras
Playback button on Sony Cybershot stopped working
you have pressed that button hard for many times.. or it may be old..
Jul 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cybershot W55 digital camera- needs proper USB connector.
Hello Voyager2Lcat,
You need Multi-Use Terminal Cable for DSC-W55 and its Sony Part Number is 1-829-866-51
Picture is attached as reference.
May 27, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
163 people viewed this question
Top Sony Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Harrie
NOEL
NOEL
Are you a Sony Camera Expert? Answer questions, earn points and help others
