You can try reseating the Video Card of the computer and check if it will boot or not. You can also try to reseat the Memories (RAM) of the computer.
Hope this helps!
If you heard a beep sounds it means there is a trouble with your memory (RAM) to fix this open your CPU cover, release your ram and try to clean up your RAM (golden color which will connect to the motherboard) using a pencil eraser, and try to remove the dust from the motherboard. After it cleans put again your RAM to the slots and please be careful to put it on right like it was before. Hope it helps
Thank you for visiting FixYa
SOURCE: My Dell Optiplex GX270 continues to go into power saver mode.
It turns itself off when there is something wrong with it. You can check the system events from the bios menu why it does that. When it doesn't boot at all check the abcd lights at the back.
