Question about Electric Mobility Pronto M41 Power Chair Electric Battery Wheelchair
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the wheelchair on when I charge? Should I let the batteries run down before recharging or should I recharge daily? Is there a sequence I should use to plug things in? Thanks.
Posted by joepage52 on
lennieg2000
  • 692 Answers
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
Posted on May 30, 2011
kb48694
    New Friend:
    Problem Solver:
  • 6 Answers
The modern chargers for Hoveround that are NOT aftermarket, are all smart chargers. You can just plug them in anytime. I do not unplug the AC nor do you need to turn off the switch on the charger. Just turn off the chair, and plug it in. The LED on the charger will change from green (standby) to red charging. When the charger has fully charged the batteries it then will turn itself off to sleep mode.
About once a month either leave your chair on and allow the batteries to run down to either where the chair shuts off, or to the last 1-2 leds flashing stage. Then do a fully overnight charge. This will keep the batteries in good shape. Do not EVER leave the chair for long time in its uncharged state if at all possible The lead acid and/or Gel cell batteries want to bwe fully charged as much as possible but you need to exercise them to obtain max battery life. The smart charger simply cannot overcharge so leaving it connected 24/7 when the chair is not in use, is really just fine. If the charger is taking a very long time to charge them or the chair has very short range, then its time to replace the batteries period. Wheelchair batteries depending on your usage will only last 6 months to a year, although many push them to as much as 5 years.
Posted on May 05, 2014
How to recharge but I get a flashing red light on transformer in battery box. this is a Invacare Pronto M91 Electric Wheelchair
The red light on the transformer/Charger means the charger is bad. Sometimes it can also be battery harness wiring. Most often it is the charger that needs replaced.
Jun 22, 2014 | Invacare Supply Group Invacare Pronto M91...
Where is circuit breaker on pronto m 41
The M41 does not have a circuit breaker, even if the owners manual says it does. There are fuses instead. One fuse on each battery. It is a very different looking fuse than one is use to seeing.
May 07, 2014 | Electric Mobility Invacare Pronto M41...
Pronto M51 Wheelchair doesn't have as much power as it used to. Batteries are good.
Have you had the batteries load tested? How do you know the batteries are good?
Apr 21, 2013 | Invacare Pronto M51 Power Wheelchair
I am getting a flashing green light when I try to charge my batteries on the Pronto M51 what does this mean
why did you change the batteries, did you verify that it wasn't the charger in the first place, sometime the charger will appear to charge but actually isn't. put a meter on one battery then plug in charger if voltage goes up charger is good if not look for loose connections and or bad charger.
Sep 25, 2012 | Invacare Pronto M51 Power Wheelchair
Is there fuses in the M91 Pronto Onboard charger
I had this exact same problem after having my M91 in the shop. The repair man said that the onboard charger was bad, so he sold me an offboard charger to charge through the arm. That didn't change anything. I finally took it apart myself and discovered that there was a cord leading from the onboard charger to the batteries that the repair person had left unplugged when he installed my new batteries.
What I'd thought was "fast draining" of the batteries was actually the batteries self-charging overnight (which they will do a little bit if you let them sit). Of course, this might not be your problem, but I'd say at least look at it as a possibility.
Aug 23, 2012 | Invacare Supply Group Invacare Pronto M91...
O have a Pronto M 41 and was bought in 07 but am having problams with turning on and shutting off.Could you tell me what it could be.
Have you replaced the batteries ever? I was told by my local Invacare vendor that the batteries are only good for 12-18 months. My mom's Pronto M41 was having battery problems and replacing both batteries solved the problem in her chair bought in 2007. Now she is looking to buy a slightly used chair (4 mos old) from the family of a deceased friend and there seem to be issues with the batteries in this almost-new chair.
Sep 11, 2011 | Electric Mobility Invacare Pronto M41...
Someone gave me a pronto m51 sure step motorized wheelchair but no manual was given..my question is: Is it safe to charge the battery overnight? Is there any danger of overcharging? If anyone knows for...
Jo, nope you are safe. Most of the chargers are designed to cut off and go into trickle charge once they sense that the batteries are fully charged. The problem with overcharging comes after 18 hours or so. You should never leave the charger plugged into the chair for more than 24 hours. On the M51 the charger is built into the chair so just plug it in when you go to bed and unplug it when you get up and you'll be ok. You can check for full charge by looking at the charger there should be a red light and a green light when fully charged. Hope this helps
Sep 08, 2010 | Invacare Supply Group Invacare Pronto M51...
My invacare pronto m51 wheelchair does not turn on. we just had the battery replaced. when it is plugged in the battery lights turn on and when you unplug it they do not even turn on.
Did you replace both batteries? How old is the chair? Sometimes the on-off keypad becomes worn and does not make contact with the on-off switch. When charging the joystick lights can light up but after unplugging they should remain on. When you plug in the charger look under the rear cover at the charger you should see 2 lights, one red and one yellow to indicate that you are charging the chair if you do not see both lights lit then the charger is bad or has a blown fuse. Only a Tech will be able to tell what is wrong. If Medicare purchased your chair then they will pay for most of repair costs. Contact your provider or a repair service company
Aug 16, 2010 | Invacare Pronto M51 Power Wheelchair
How do I charge My Pronto M51 motorized wheelchair?
Margie,   Yes you may charge it overnight. If you use it everyday,charge it every night. Once the charger senses 24 volts it stops sending a charge,so they cannot be overcharged.  I suggest when you go to bed put on the charger and unplug it when you get up in the morning.
Mar 28, 2009 | Invacare Supply Group Invacare Pronto M51...
Battery won't charge
Most likely you need new batteries. On the M51 powerchair the batteries are located in the center under the seat. Step 1 - remove the seat by pulling up on the swivel handle while lifting straight up, the seat weighs about 50 lbs. After removing the seat remove the center plastic cover by liting it off.
If you have an older model M51 the batteries will each have their own cover - to replace the batteries you will see several connectors that must be unplugged. The front and rear batteries each have different connectors so keep them separate. Lift out the batteries and follow the wiring for each replace the batteries. You will need 2 U1 batteries, available at sears or your local maedical equipment supply store ( Interstate has them too) Simply reverse the removal procedure to replace the batteries making sure you follow all the connections. - good luck
Tom
Mar 20, 2009 | Invacare Pronto M51 Power Wheelchair
Electric Mobility Pronto M41 Power Chair Electric Battery Wheelchair Logo
724 people viewed this question
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
