Question about HP LaserJet 5si mopier Printer
Printer prints all pages onto one page.
I have Windows XP and printer was working fine and then I connected an Epson CX6400 up and moved the cable to another usb port and now it prints all pages on to one. All the text is there, it just is not readable. I have tried to install new drivers but that doesn't work.
Any help will be greatly appreciated.
Posted by davieplace on
  • Anonymous Sep 04, 2008
    I have windows xp, I did not change printers, but it seems that after a windows update all the pages print on one page.
  • soloco Jan 28, 2009
    First my printer was printing very light after replacing the toner. Self test pages were printing just fine. I deleted the driver and installed a new driver and many other drivers and still get the same problem.
5 Related Answers
Metawatch
Ken Flack
  • 96 Answers
SOURCE: Epson Stylus CX6400
Blank pages are indicative ofdried ink.
If the printer has not been used for a long time ink may have settled and dried in the heads.
You may need to replace the cartridges (IF they are very old) and run several head cleanings if there is no improvement.
I typicall try to print a few test pages to see if some of the color work.
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Posted on Feb 09, 2008
Anonymous
SOURCE: Epson rx420 printer
Another post suggests that you printer is dead -see (http://www.fixya.com/support/t354202-epsom_rx_425_just_prints_half_page) but I've had the same problem - things seem to be ok after I reset to the defaults in the main page of the printing preferences.
Posted on Mar 15, 2008
IB4G2008
Patrick Michaels
  • 3587 Answers
SOURCE: hp laserjet 1320
well..you may find that driver here, though
Posted on Mar 17, 2008
Anonymous
  • 150 Answers
SOURCE: epson LQ -590 PRINTER PROBLEM
  1. You text page is larger than the printer page,
    margins are set wrong, or there are special
    formatting marks and/or characters at the end
    of your documents.
  2. Check default printer paper-size settings:
    START --> Printers & Faxes -> Chose printer -->
    right-click --> properties --> ....
    This sets the default settings, that are in effect every time
    an application starts up.
    Also note, that if printer settings are not listed within
    your START menu, you can find them in the Windows
    control panel. You can change what shows in the
    START menu and what doesn't by right-clicking the
    task bar.
  3. Now start your application and do the same thing under
    the file menu:
    File --> Print --> Settings ...
    File --> Printer settings ...
    File --> Page setup .... and also margins. etc...
    This sets the actual settings for this application or the
    current document. These settings over-ride the global
    default setting in item (2)
  4. To clarify, the settings in item (2) should be setup to
    reflect the way you use the printer the most often.
    The settings in item (3) reflect the actual document you
    are trying to print now.
  5. Be careful that the paper size settings (3) accurately
    reflect the paper in the machine, do not confuse
    metric sizes: A1, A2, A3, A4, A5 ....
    with English sizes: Letter, Legal,..... etc
    These do not line up exactly.
  6. Also check your document, to make sure that there
    are no extra characters at the end of your document:
    Paragraph marks, Page Brakes, Form Feeds, etc.
    Also check the paragraph settings (in Word for Windows,
    for example, to make sure that is not the cause of the
    problem.
    In word for Windows, for example, you can also go
    into tools, options and change the way your document
    is displayed, such that all formatting marks become
    visible (or click on the paragraph tool)
  7. Finally, most Windows applications offer some kind
    of print PREVIEW facility, so that you can see what
    you are going to get, before you physically print it.
I hope this solves your problem, please rate my answers.
Good luck.
Martin
Posted on Jul 18, 2008
Anonymous
SOURCE: Epson CX8400 Blank Pages
i was having the same problem and just got off of the phone with tech support who fixed the problem for me,
go into system preferences
print and fax
there you should see the printer cx8400.
remove the printer by clicking on the - sign.
then re add the printer, by clicking the +
the computer will search for the drivers and install them.
that should have you printing like a champ.
hope this helps.
WW
Posted on Aug 13, 2008
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <[email protected]> wrote in
message news:[email protected]
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
My epson stylus tx 121 doesn't print..... it says ur printer s not ready... but everything s ryt at my end.... i need some solutions
First how are you connecting to the printer? Is it a direct USB connectionor are you using a USB hub or print server (sometimes part of a router)? If a USB hub is in use, is it a USB powered hub or a self-powered hub (AC adapter)? (Make sure that the printer has power and is turned on. Also make sure that you have printed and scanned a calibration )
If you are not using a direct connection, try a direct USB connection. Use a different USB cable and try different ports (some ports have lower power throughput than others). Make sure that you have the correct driver for your OS. (The full software is useful for other issues.) See http://www.epson.com.ph/epson_philippines/printers_and_all_in_ones/inkjet/product.page?product_name=Epson_Stylus_TX121 for the drivers.
Try uninstalling the current printer driver and then disconnect your data cable (USB). For Windows, press Start and open the Devices and Hardware control panel (Printers and Faxes in XP) from the right hand column. Right click on the printer and select Uninstall (or left click and choose Uninstall from the Menu bar). Reboot the computer and install the Epson printer driver before reconnecting the USB cable. (Otherwise you can get the OS driver that may not work as well.) Remove your data cable from both the computer and the printer and turn off both devices. Unplug the power cord from the printer and the wall outlet. Wait a few minutes before reconnecting the power. (This will reset most printers if there is an error in the printer itself.)
If you are using a print server and the direct connection worked, check the installation information for using the print server. Not all printers are compatible with certain print server drivers and you can have a conflict.
If a direct connection to any of your computer's USB ports does not work, check if other USB devices work. If not, try updating or uninstalling your USB controller (in the Device Manager for Windows - Start > Control Panel > System and Security > Device Manager, scroll down to the Univeral Serial Bus controllers). Then reboot your machine and see if the correct driver installs. Alternatively, check your computer manufacturer and see if there is an update for your USB driver.)
If the problems persist, you may have a bad USB port on the printer. Please add a comment with the type of connection between the computer and the printer.
I hope this helps.
Feb 23, 2012 | Office Equipment & Supplies
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
Directions how to install
USB is pretty bullet proof. Printer USB cable ... only one end will go into the printer, the other end can go into any available USB port.
Normally, the cable does not come with a new printer. Get one at the big box store or at a computer store or look at Kmart
I hope this helps you
Oct 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Epson CX6400. No display. no power. does the printer have an inline fuse?
1.) Unplug all cable connections ( power cable and usb cable ).
2.) Check if there's any obstructions inside the printer.
3.) While the printer is off and unplugged., press and hold the on button for 10 sec.., release after 10 sec. and connect power cable.
4.) Turn on the power.
Apr 06, 2009 | Epson Stylus CX6400 All-In-One InkJet...
My epson cx6400 shows "status deleting" when i click print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Where is usb port for usb cable in espon cx6400
Hi
Open/lift the scanner glass. if you are facing the printer. look inside it on the left hand side there is a port for usb cable on that are.
Hope this help
Dec 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson TM on Windows XP with serial
you need to use the printer cable that was design for the printer. if you don't have the cable anymore, then you have to take the commercial cable apart and reconfigure in accordance to page 43 of the manual call outs.
Besides the cable, the printer software is only good for Windows 2000. Windows XP will not work unless Epson provide you with the printer driver. (which I did not see on the website).
all in all if you must use this printer with Windows Xp. you need to create a file in Autoexec.bat to enable the printer and allow the USB to connect to the printer.
that is going take time to do. if you need help on that. please post the request here.
Thanks
Dec 03, 2008 | Office Equipment & Supplies
USB plug in Epson Printer RX595
assuming you properly installed the "printer driver".
disconnect the printer.
check Printer & Faxes for printer icon(s) - delete print queue(s) and the printer icon(s).
open device manager and go to Universal Serial Bus Controllers section.
now we check for connectivity: (treat the printer and scanner as separate devices)
connect the printer, USB Printing support must show up (also check Imaging Devices and the scanner must also show up)
IF USB Printing support shows, windows will create a printer icon in the Printers & Faxes, right click choose properties and print a test page.
ELSE, it's the printer and request for a replacement if it is still within 1 year from the date of purchase
Jun 14, 2008 | Epson RX595 Photo All-In-One Printer
Cannot connect
have your tried removing the driver and reinstalling? sounds like a corruption to me.
been struck by lightening / power surge?
anything funky in the computer's behaviour three days ago, but not related to priner?
Mar 24, 2008 | Epson Aculaser C1100 Printer
HP LaserJet 5si mopier Printer Logo
535 people viewed this question
Ekse
efs_perpends
efs_perpends
