Question about Coby Kyros 716829701508 Tablet PC
I've downloaded teh firmware update (update.zip) to turn my Kyros mid7015 into mid7015a, and since then I can't doenload apps from appslib, I keet getting that there's not space on the memory. That was at first, now I get a message that there's a problem on the connection, but I can surf the web and download book from Adilko with no problem. Can I get bat to mid7015? Thanks.
Posted by gonzaloa2003 on
4 Related Answers
SOURCE: coby Kyros wont go to
I'm having the same issue.
Posted on Dec 26, 2010
Anonymous
SOURCE: just purchased a coby mid7015-4g
I did that myself. Apparently all the people getting them for Christmas and rushing to the site crashed it temporarily, they are working on it, it is NOT your device's fault.
No sure fix date, just keep trying.
Posted on Dec 28, 2010
Anonymous
SOURCE: Cannot access Appslib app library
I couldn't either! So, I uninstalled the appslib and reinstalled it and it works great now! You have to reset everything and you will lose apps I guess if you have any, I had none so this didn't affect me. If you go to Coby's website and under FAQ's it explains how to uninstall and install. Good luck!
Posted on Dec 31, 2010
Fred Flintstone
  • 76 Answers
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
Posted on Feb 28, 2011
Why can I no longer access my Amazon Kindle App on my Coby Kyros tablet?
Coby no longer uses GetJar, I would download 1mobile.com's - http://www.1mobile.com they have an app store that has an updated version of Amazon App Store.
Apr 05, 2013 | Coby kyros Tablets & eReaders
Can i download kindle to my coby kyros mid7024 tablet
You need AppsLib on your tablet (you can download from them), and from there you can search for third party readers (I dont think you can get kindle as its designed for phones). Android tablets dont have access to the android market place therefore tablet manufacters have their own - in this case AppsLib.
Jun 09, 2011 | Coby Kyros 716829701508 Tablet PC
My apps libaray on my coby kyros mid7015 isnt working!!! everytime i try to go into the apps libaray it keeps saying that theres been an unexpected problem and that it has to "force close" why is...
Go to Settings.
Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
Process com.appslib.vending on my coby kyros tab. Any solutions?
Installing the Windows software, Kryos USB drivers, and updating your Appslib:
  1. Download and install The Java Development Kit 6 here: https://cds.sun.com/is-bin/INTERSHOP.enfinity/WFS/CDS-CDS_Developer-Site/en_US/-/USD/[email protected]_Developer
  2. Download and unzip the android-sdk-r07-windows.zip file to the C: drive on your computer: http://developer.android.com/sdk/index.html
  3. Go to the android-sdk-windows folder that you unzipped
  4. Launch SDKManager.exe
  5. Under choose which package to install, click accept all. As a part of what it is downloading, it will download the Android USB drivers. This part will probably take like 30 minutes or more to complete.
  6. Once the download is done, close the SDK Manager.
  7. You should now see a folder called usb_driver. Open that folder.
  8. You will see a file called android_winusb.inf. Replace that file with the one downloaded here: http://rapidshare.com/files/435451166/android_winusb.inf
  9. Plug in your Kyros device. Windows will still not find the driver for the device, but go into the Device manager, and select AndroidEclair, and update driver, browse my computer, let me pick from a list of device drivers on my computer.
  10. Click "Have Disk" and browse to the c:\android-sdk-windows\usb_driver folder. Double click on android_winusb.inf.
  11. Select Android ADB Interface.
  12. It will then come up with some messages about this is unsigned or something, are you sure you want to do this, click yes or continue.
  13. Then it will install the driver and detect the kyros.
  14. Download appslib_2.apk here: http://files.appslib.com/apps/marketplace/v2/Appslib_2.apk
  15. Make sure you have external SD card (optional)
  16. Make sure your wireless is setup, on, and works.
  17. Under Settings (press the M button on the home screen to access settings)
  18. Select Applications, and make sure Unknown Sources is checked.
  19. On the Force prompt, select wait.
  20. If step 19 doesn't work you have 3 choices: A: call their customer service B: return to the home screen or C: Go to step 21
  21. Get the Droid Explorer for your Windows PC
  22. Make sure your KYROS is connected to the PC and launch DROID Explorer.
  23. Now you can uninstall apps or install apps.
  24. You need to download Appslib_2.apk, if you haven't already, click here and download the file to your PC.
  25. Uninstall the old Appslib before you install the new version Applib2.
  26. Transfer the Appslib_2.apk file to the [DOWNLOAD] folder on your device. Unplug your device.
  27. Open the File Manager on your tablet, go into the Download folder, and tap twice on the Appslib_2.apk file that you will find there to start the installation.
  28. Follow the on-screen instruction to install this newer version of the Appslib applications.
  29. At the end of the installation, select: "Open".
If you have an app that won't install correctly or is not working at all, you could try and download the Appslib update or upgrade here: http://www.cobyusa.com/?p=prod&prod_num_id=10498&pcat_id=1013
An alternative to the Appslib is Andexplorer, available here: http://www.lysesoft.com/products/andexplorer/index.html#download
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 24, 2011 | Coby Kyros 716829701508 Tablet PC
I'm interested in downloading an android app that will allow for the creation and editing of a word document on my Kyros MID7015 Tablet. Does such an app exist, if so, where, and how to download?
The best option in the long run is to root, and install the market. This will give you access to all android app's which will allow you to run plenty of apps that will do what you are looking for. Here is the "how to" http://tipstir.the-talk.net/mid7015-4g-rooted-rom-f76/coby-kyros-mid7015-android-tablet-ultimate-beginners-guide-on-how-to-root-your-tablet-install-clockworkmod-recovery-to-do-a-complete-systems-backup-and-then-install-google-market-t689.htm
Hope this helps.
Feb 15, 2011 | Coby Kyros 716829701508 Tablet PC
I cannot open AppsLib on my Coby Tablet.
Dec 31, 2010 | Coby Tablets & eReaders
When i go too the Appslib it dosent wrk and it says try again later and it wont never work
First, make sure the wireless is on and working. You may require the Appslib update.
The following will guide you through Installing the Windows software, Kryos USB drivers, and updating your Appslib:
Dec 30, 2010 | Coby Kyros 716829701508 Tablet PC
Appslib won't download
Cannot access Appslib app library on Kyros tablet, using wifi. Will not allow downloads and constantly discontented.
Dec 29, 2010 | Coby Kyros 716829701508 Tablet PC
Coby Kyros 716829701508 Tablet PC Logo
109 people viewed this question
Top Coby Tablets & eReaders Experts
Marvin
Marvin
Edward Morgan
Edward Morgan
Harrie
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
