Phillips Magnavox TV, GE Universal Remote. I've gone through the set up w/o codes since the codes in the pamphlet did not work. I still cannot get the codes set. (set up, TV, channel up button until the channel changes and then enter button) I did it once and it worked for a hour the second time I could get channel up/down and mute but no buttons and now I cannot get it to set codes again. Help, please. Thanks.
Posted by yvetteski on
5 Related Answers
Anonymous
  • 317 Answers
SOURCE: Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Posted on Sep 11, 2007
Anonymous
  • 50 Answers
SOURCE: emerson tv codes for GE RM-24930 4-Device Universal ...
check this site for your codes. (Jasco is GE)
http://www.jascoproducts.com/support/universal-Remote-codes.asp
Posted on Nov 18, 2007
Anonymous
  • 476 Answers
SOURCE: Universal Remote not working
With nearly all brands of universal remote control, there is usually more than one code for Philips. Keep going through the codes until you find one that works correctly.
So if you know that the 1st code doesn't work, then don't save it, and move to the next.
You may find that several codes will actually put the TV into standby, but other functions will be different.
Posted on Mar 13, 2008
Anonymous
  • 207 Answers
SOURCE: Magnavox TV all in one remote code
http://www.urc.philips.com/
Posted on Apr 29, 2008
Anonymous
SOURCE: program a ge universal remote to an emerson 12" tv
i have a ge RM24911 universal remote but i need the codes
Posted on May 13, 2008
I have a ge universal remote and my tv is a Magnavox can I find the code for my tv with this remote
You can use code search to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote (such as Philips). All universal remotes do not store all possible codes.
Jul 07, 2016 | GE Televison & Video
I have a ge universal remote. I've put in all the codes to my tv and none of them worked. My tv is a magnavox mod# 20ms34442/17 can you help?
What model number of the remote do you have? I also have a GE universal remote and I have used it on over 30 tv's and every single 1 worked. Do you do the autoscan or put them in manually?
Dec 30, 2012 | Philips Magnavox 27MS343S 27" TV
I NEED TO PROGRAM A MAGNAVOX TV WITH A PHILLIPS UNIVERSAL REMOTE CONTROLL
Find codes and methods here.
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
Oct 08, 2010 | Universal Remote Control Universal IR...
I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Oct 19, 2009 | Philips Magnavox Learning Universal Remote
New GE universal remote, but none of the codes work for my tv
Try one of these magnavoz codes=164-116-003-363-333-226-390-467-431-594, put them in remote one by one. Hope they work for you. God-Bless! These are the codes I got with my remote!
Oct 27, 2017 | TruTech T2000D TV
General electric Universal remote control codes
i lost my code book for my ge remote control
Apr 11, 2008 | Broksonic CTVG-5463GVC 19" TV
Televison & Video Logo
215 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
