Question about Gigabyte 7nnxp Motherboard
Gigabyte not starting at all
When i push the button to turn it on all it does is the lightr on the board comes on the green light comes on on the tower and the keyboard dnt work the moniter does not come on the mouse dont work it seems like it doesnt boot or notheing i get noyting out of it i thought it migh5t bve the ram but ive got ddr ram 4oo in it what do i do next
Posted by jerryramsay on
Michael McClure
    Habit-Forming:
    New Friend:
  • 65 Answers
Edit your question and display the make and model number of your motherboard. Do you hear beeps (How many) when you try to turn it on. You said you have ddr ram (ddr is an old hardware). Hardware such as RAM, CPU, PCI slots, ETC ...must be compatible with your mother board.
Posted on Oct 24, 2017
5 Related Answers
ardmax
Massimo Ardito
  • 155 Answers
SOURCE: change sd ram to ddr ram
Because you didn't indicated the version of you motherboard I need you to go to the ECS website http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=190&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
On your left select product category motherboards, socket 478, model P4VMM2, the right version and download the manual for your motherboard.
If you look the manual there are few jumper that you need to change.
Usually JP1, j2 and J3 like on this picture.
Let me know if you have problem with the manual, you can give me the version type and I'll find it for you.
Posted on Oct 23, 2007
map9966
Mike Peluso
  • 2351 Answers
SOURCE: Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Posted on Jul 24, 2008
Anonymous
  • 17 Answers
SOURCE: Gigabyte GA-K8N Pro-SLI won't boot and no beep codes
hi kathy,
there are a few things you can try, reseting the cmos, with the jumper usually located near the battery. if you cant find that, try removing the battery for 30 mins and then popping it back in. if no luck from there, you could try another cpu, if that dont work then it may just be the mobo! good luck!
hope it helps!
Posted on Feb 11, 2009
Anonymous
  • 948 Answers
SOURCE: gigabyte k8m800-8237 won't boot with 2nd gig ram installed.
Could have been dusty. Find a copy of Memtest and run it to check things out. Errors could mean a bad stick or bad slot.
Posted on May 03, 2009
Anonymous
  • 381 Answers
SOURCE: the phase 4 led on my gigabyte ep43-ud3l ights up
hi..the mother is need a complete the supply on board pin..then double cheek the memory..thanks..Good Luck...^_^
Posted on May 13, 2009
I cannot get my Veggie Bullet 's motor to come on. Red light comes on, but when I push the button again the light turns green, but the motor will not engage.
The motor may have gone into thermal shutdown due to overheating but also the motor could simply be defective.
Mar 28, 2018 | Televison & Video
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
    you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
    Aug 18, 2012 | Sony Playstation 3 (PS3) Console
    Tv turns on green light blinks three times then TV turns off
    Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
    Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
    I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
    This is directly from the User Manual:
    If the computer is connected to an electrical outlet, the Battery light operates as follows:
    • Solid green: The battery is charging.
    • Flashing green: The battery is almost fully charged.
    If the computer is running on a battery, the light operates as follows:
    • Off: The battery is adequately charged (or the computer is turned off).
    • Flashing orange: The battery charge is low.
    • Solid orange: The battery charge is critically low.
    Dec 27, 2009 | Dell Inspiron 1525 Notebook
    The red standby light flashes and when the power button is pushed the green light comes on with a clicking soung then it turns back off and the red standby light starts flashing again
    One of the boards (module) has a short on it, and or the power supply itself is failing.
    The service center will find the fault using the process if elimination. They will replace the bad boards or modules as required to get the set working again.
    Jerry G.
    Dec 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
    I have a RCA RT2250 and I have a green light on a circuit board
    Check the solder connections on the seven voltage regulators found in the center of the receiver on the heat sink from front to back (not the amp board) they are on the main board. The green light on the DSP board (back right side) is an error light. You can reset the receiver by pushing power then stadium then night then dsp off then club after unplugging the receiver and plugging it back in.
    Hope this helps,
    JohnW
    Jan 10, 2009 | RCA RT2250 System
    Gigabyte 7nnxp Motherboard Logo
    Top Gigabyte Computers & Internet Experts
    Lee Hodgson
    Lee Hodgson
    Tareq Bin Mostaq...
    Tareq Bin Mostaq...
    Ekse
    Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
