If the computer is consistently picking up the Saitek ST90 and it still isn't working it could be a problem with the game rather than your stick.
Do you have another game you can test it on even if it isn't meant for it? Just to see if other games pick it up.
If they don't then I would reinstall all drivers first, if they do get picked up then your best bet might be to reset game to factory settings and if no luck then reinstall the game.
SOURCE: saitek aviator joystick av8r-01
Well.. if you have windows xp.. then you can calibrate your controller fairly easily.
Go here:
Control panel:Printers and Other Hardware:Game Controllers:(your controller should be in the list):Advanced:Calibrate
This should solve your problem ;)
SOURCE: Saitek X52 Joystick
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
SOURCE: Use of AV8R-01 with Google Maps flight simulator
My blackwidow joystick would not work in google earth, the sim would just crash. I tried a surgestion to remove the blackwidow software and just run it with the ms hid driver. It now works fine, even the throtle and rudder controls.
I had the same problem.
Unplugging the joystick and plugging it back again seemed to fix it for me.
Don't know whether it will work each time.
