Question about Norcent Technologies LM-760 17 in. Flat Panel LCD Monitor
My monitor takes along time to brighten up?
The left side tends to be the darkest, so I've been minimizing my windows and dragging them to the right to see! I realized if I left my monitor on with slideshow of my pictures that it wouldn't go dark again...but the other day I forgot and know its dark again...ugh...What to do?
Jen
Posted by zenquisjen on
Adam Scoggins
    New Friend:
  • 6 Answers
I don't know does it?
Posted on Feb 08, 2018
Can i connect two monitors to a nvidia geforce 315 card so as too use two monitors
hi,
yes the 315 desktop card does have multi monitor support. you may however need an adapter for one monitor as it only has one dvi ,one hdmi and one vga.
so you can hook up any 2 as a combination but they have different plug configurations to do this
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Sep 16, 2011 | Computers & Internet
On my Toshiba Tecra when in GoogleChrome the the image on the screen is 25mm too far to the right. This makes it impossible to use the up/down key at the top right of the screen and the enlarge and...
Have you tried double clicking on the bar right at the top of the screen next to the minimize, maximise, close buttons? By double clicking in this area it'll change the size/shape of the browser screen, you can then reposition the window to the top left of your screen and then click and drag the bottom right hand side of his window once the cursor turns into a double headed arrow.
Apr 18, 2011 | Computers & Internet
TRYING TO CONNECT TWO MONITORS FOR EXTENDING USE
1) You have to have a graphics card with two monitor ports.
You Cannot use one port on a graphics card, and the VGA, or DVI port on the motherboard of the computer.
BIOS will only let you use the graphics card, or the Integrated Graphics.
2) Using a 'splitter' cable results in very bad graphics on two monitors, or no graphics at all.
3) With a graphics card installed that has two monitor ports on it, connect the monitors to the graphics card.
[ The graphics card can have a VGA port, and a DVI port. Or the graphics card can have two DVI ports.
VGA = Video Graphics Array
Photo of a VGA port,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
Photo of a VGA cable,
http://en.wikipedia.org/wiki/File:Vga-cable.jpg
DVI = Digital Visual Interface
Information about DVI showing a DVI cable, and connector examples for the DVI port on a graphics card,
http://en.wikipedia.org/wiki/Digital_Visual_Interface ]
4) Turn the two monitors on once they are connected to the graphics card.
Turn on the computer.
5) Windows loaded, right-click on an empty area of the desktop screen.
6) In the list go to the bottom, and click on Properties
7) Click on the Settings tab.
8) You will see two monitor icons.
One icon has a square with a 1 in it.
The other icon has a square with a 2 in it.
The 1 monitor icon is used to represent your Primary monitor.
The one you have been using.
As you can see the 1 monitor icon is sitting to the Left.
This is how your Primary monitor should be sitting on your computer desk.
The 2 monitor icon is used to represent your Secondary monitor.
The one you are going to add.
As you can see the 2 monitor icon is sitting to the Right.
This is how your Secondary monitor should be sitting on your computer desk.
Left-click on the 2 monitor icon.
Go below in the Display Properties window, and view where it states -
Extend my Windows desktop onto this monitor
There is an empty square to the left of it.
Left-click in the empty square.
Now go below to the Right, and click on - Apply
Finally go below to the Left, and click on - OK
Your desktop screen will now be on your Secondary monitor.
Whatever is on your Primary monitor, has to be drug over to the Secondary monitor, when you are on the internet, or a program. (Such as a game)
Go to the blue frame on the Left side of the Windows screen.
When your cursor turns into a double-headed arrow STOP.
You'll find it's a little tricky your first time, keeping your cursor into the position where it turns into a double-headed arrow.
With the cursor in a double-headed arrow, press the left mouse button down, hold it down.
Drag the monitor screen to the Left.
Keep dragging until the window on your Primary monitor is on your Secondary monitor.
It's helpful you'll find to have two of the same size monitors.
I have found occasion where when using the internet on two monitors, that I had to Restore Down the screen, THEN drag it over to the Secondary monitor screen.
(Icons at the top right of the monitor screen.
Minimize ( - ), .......Restore Down/Maximize, ...........Red X
Then I Maximized the screen
For further questions please state in a Comment.
(Believe upper right of your page. - Comment
Nov 02, 2010 | Computers & Internet
How to minimize messages in Toshiba laptop
Try holding your mouse at the edge of either side of the open window till you see a 2 sided arrow and hold down your left click button on your mouse,then drag the window to the left or right to make it smaller.You should then be able to minimize all your windows again.Good luck ,please let me know the results:)
Apr 12, 2010 | Toshiba Satellite A60 Notebook
How can we connect two moniters to one cpu
To have and use 2 monitors at the same time, you need a video card with a dual VGA outputs.
To use 1 monitor at the time you can buy a VGA switcher, to switch between the 2 monitors.
Best of Luck
Sabre
Feb 18, 2010 | ViewSonic Computers & Internet
Ati radeon X300 SE how to get both monitors working at the same time. Windows XP screen settings and ATI Catalyst Control Center can see only one at a time, but not both...
Use the DVI port, and the VGA port on the ATI Radeon X300SE graphics card.
If you have two monitors that are LCD, and they both have a DVI connector, use a DVI to VGA adapter for the VGA port on the ATI Radeon X300SE.
[You need a Female DVI to Male VGA adapter, such as this example,
http://www.directron.com/dviadapter.html
Turn both monitors on. Right-click on an empty spot on the desktop screen. Left-click on Properties, then the Settings tab.
Left-click on the monitor icon with the 2 in it.
Go down to ->Extend my desktop to this monitor, and left-click in the box to the left of it.
Go down to the right, and left-click on Apply.
Now go over to the left, and left-click on OK.
You should now have your desktop screen on both monitors. When you open a window on your Primary monitor, (Monitor icon 1), Left-click on the frame, hold the mouse button down, and drag this screen to the Secondary monitor.
If it doesn't work this way, drag to the other side.
Sep 07, 2009 | Computers & Internet
I JUST CONNECT A SECOND MONITOR TO MY EXISTING RADEON 7500. I ALREADY SETUP THE 2ND MONITOR ON THE DISPLAY PROPERTIES ( WINDOWS XP) I CAN SEE THE MOUSE MOVING FROM ONE MONITOR TO THE OTHER, DOES ANYBODY...
you'll have to drag them windowed to your 2nd monitor. Windows automatically will use your primary monitor unless you use software to control where which programs will load.
A good program to use is called Ultramon.
Sep 02, 2009 | Dell RADEON 7500 AGP Graphic Card
Norcent Technologies LM-760 17 in. Flat Panel LCD Monitor Logo
Top Norcent Technologies Computers & Internet Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Norcent Technologies Computer and Internet Expert? Answer questions, earn points and help others
