This used to happen all the time when I had one. The best thing to do is to completely uninstall the printer and all it's added programs from your computer.
Switch off the computer and let cool down (have a cup of coffee) Now reboot the computer and then reinstall the printer and follow instructions to connect via Wi Fi
If this works make sure auto update is switched OFF as every time mine was updated your problem occurred. So much for Degreed wonders who try to justify their existence and completely mess up a perfectly sound working system when they don't know what they are doing, shame they never seem to have a brain or any logic.
SOURCE: Kodak 5300 printer problem
I would suggest the following :
1) Remove the Kodak printer and all its software.
2) Disconnect the USB cable from the computer.
3) Reinstall the entire software applications for the printer just as if you were installing it for the first time.
4) When asked to connect the printer .. Use a different USB port .. even if you have to switch something out .. but do this step irregardless.
Now what I want to know is ..
1) Can you print from the computer?
2) Black still "gone" ?
Let me know
SOURCE: No Kodak printer detected
call kodak @ 1800 421 6699. they will fix ur problem. if nbot,they will replace ur printer or may be software issue with ur printer they will assist u better as this issue cannot be solved orally or by chat
SOURCE: Kodak ESP 7 WIFI problems
The ACTIONTEC GT124, M1000 and PK5000 Routers are not compatible with wireless-enabled all-in-one printers. These routers cannot connect to your all-in-one printer because they do not support the multicast protocol. Contact your router supplier for additional assistance and to determine if your router will be able to support the muticast protocol in the future.
Hi krdur99, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
what ip address does the printer use ?
is it a static ip address or is it allocated dynamically or its ip address could be allocated to another device dynamically ?
