Question about Nspire Audio Players & Recorders
Nspire MP 752S
A friend gave my son this player that he didn't use anymore. When we plug a USB cord in it shuts off and doesn't show anything on the screen. He had lost the software that came with the player but I thought XP would detect it automatically. Do you think I need to reset it before it will work with my computer? He has several songs on the player but my son would like to add more. Thank you.
Posted by tngirl1127 on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Media Full, Shutting Down
Have you contacted Memorex?
Posted on Feb 06, 2008
BerkelUSA
Rob Cummings Jr.
  • 24 Answers
SOURCE: How do I add songs to my Sony Walkman NWZ...?
Windows Explorer works! - Just put the MP3 files in the "MUSIC" folder when the drive letter shows up after you plug it in - I found that WMP can see mine but doesnt like to do anything with it as far as transferring files.. Look again in the Fixya page for this model player as I just listed how to convert videos correctly also. [email protected]
Posted on Dec 27, 2008
dewan nafees ahmed
  • 1894 Answers
SOURCE: My PMP MP4 player's LCD screen is not working.
hi,
i dont think you can solve this very easily. try to do a firmware update of the player.
if the firmware update is no there then there is very little chance to clear this problem.
thanks you
Posted on Feb 08, 2009
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: My computer isn't detecting my Sansa mp3 player anymore.
First, make sure the lock switch isn't engaged.
Try this: disconnect the player from the computer, turn it off, hold in the volume + (or Record) button, and reconnect the player to the computer while holding the volume + (or Record) button in. Keep holding the volume + (or Record) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start --> Control Panel-->System--> Hardware--> Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Posted on Feb 28, 2009
Anonymous
  • 4 Answers
SOURCE: My Coby MP-705 Won't Delete Songs
I had the same problem - VERY frustrating. Just found the answer, and am very happy to share it!
1. In setting/USB mode, select MSC mode.
2. Plug in Coby to USB
3. Open My Computer. Look for the Coby as a REMOVABLE DISK, not the Coby.
Files will be there for Viewing and Deleting! (On XP, at least).
4. Make a backup of MTP.BIN and WMPInfo.xml, which I think is the operating sytem?
I got the clue from here:
http://www.fixya.com/support/t357600-problem_coby_mpc7095_2_gb_mp3_player
Paupaul
Well, turn on you mp3 player, go on setting/USB mode and select MSC mode.
Then plug it on your computer and check in MICIN.DIR folder. You must find them.
It wasn't exactly what I saw, but once I looked, it was all there. Perfect!
Posted on Mar 04, 2009
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
Dec 21, 2010 | Sony Walkman NWZ-E344 Digital Media Player
A friend gave me his gpx do i need software to install on pc?
I don't think you should require anything. When you plug it in via the USB cord it should automatically install the necessary drivers. You will need Windows Media Player 10 or higher to load songs onto it though.
Jun 23, 2010 | GPX ML648B MP3 Player
Can't get Icon to show up on my computer
I am having the exact same problem, only I am on a PC using Vista. Can someone please help?
Mar 02, 2010 | RCA M4304 Digital Media Player
Coby MP-200 wont register on windows xp
This is a flash device and it comes with a USB extension cable, try not using the extension cable and plugging the unit directly into one of the REAR usb ports on your computer. This should make the device show up as a 'Removable Disk' drive under 'My Computer'.
Aug 14, 2008 | Coby MP-C883 MP3 Player
Coby mp-c827 mp3 player
your probably using the usb extension cable, plug the unit directly into one of the rear ports on your computer tower and it should show up..these units never break..unless there is physical damage itself.
Aug 10, 2008 | Coby MP-C827 MP3 Player
HELP ME PLEASE!!
I'm not sure which Coby I have but my computer wouldn't read it when I plugged it into the USB port. What worked for me was to take out the battery, plug it into the USB port, add a couple of mp3 songs, unplug it and plug it back in. It was recognized with all the existing media on it and I could edit and delete. Hopefully you have room to add an mp3 or two. My solution last time it happened was to reformat and reload.
Aug 08, 2008 | Coby MP-C827 MP3 Player
Coby MP-C7085 Wont work
These players are plagued with problems! I have the 2gb version which does the same thing. I gave up on trying to use its internal battery and bought a usb charging cord for use in my car. I just unplug the cord from the cig lighter socket when I'm done using it. If it doesn't shut off,which is 99.9 percent of the time, then it just runs its battery down until it finally shuts off. It's a shame this player doesn't work as good as it looks...
Mar 18, 2008 | Coby MP-C7085 MP3 Player
Please help
sorry u need to purchase a knew one either your connections were messed up on your usb cord or its simply jus not in process anymore bring it to someone who knowa how to fix mp3 players or purchase a new one WAL-MART HAS SOME GREAT DEALS ON THEM
Jan 18, 2007 | Coby MP-C641 (256 MB) MP3 Player
Rave mp mp3 player ---- frozen
Try a separate SD memory card (no bigger than 512mb). Also try replacing the battery if you haven't already. Mine has done this intermittantly since it was about a year old.
Jun 28, 2006 | GoVideo Rave-MP AMP512 MP3 Player
50 people viewed this question
Top Nspire Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Nspire Audio Player and Recorder Expert? Answer questions, earn points and help others
