2001 Volkswagen Beetle Logo
Posted on May 24, 2011
Car running fine then stopped in store then got into car try to start it wouldn't got it jumped got it home radio didn't work and now it won't start again. Windows work and no warning lights came on prior
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 29, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
316
Points
I think is the gas fuel pump if u didnt saw any warning lights (it never shows for some reason)
2answers
My 99 Jetta won't start.
still could be starter look for bad fuse and neutral safety switch cluch switch bad cables
I have a 2001 buick regal ls, the problem I'm
Have a look for a hole in the block where the oil is coming from. If you have one you have blown a motor.
I have a 1987 Dodge Aries and I'm having problems
There's a bolt and a plate near the bottom of the battery holding the battery in the tray. Did you take that bolt out and lift the plate ?
My 2007 dodge charger didn't crank so I jumped it
A battery from 07 is still decently new to be that bad, but I would check the alternator first, just get the car running and unhook the positive cable from the battery, if the car dies the alternator is bad.
2answers
What could be causing my 2005 mazda 6 to keep dying while I am driving it?
Have the codes read with a scan tool. Most auto parts stores will do it free.
Went to the mall and got back to car and car wouldn't start. Had to call roadside assistance for a jump. Got home, turned car off and car won't restart. No interior lights.
Sounds like a dead battery, the fact that you were able to drive it all the way home after being jump started means that your alternator is working fine, but as soon as you turned it off there is no way to restart it since the battery is bad. Take out the battery and go have it tested at your local auto parts store to be sure, but that is most likely the cause.
2helpful
2answers
2006 jetta tdi radio not working after jump start
battery is dead... have the battery and alternator tested for functionality
10helpful
2answers
2004 Ford Explorer Won't Start
check the crankshaft sensor they are good about going out on the explorers
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
