Hi, Thermostat Operation:
Your engine must be cold before removing the thermostat.
Find the location of your thermostat by following the rubber hose located on bottom of your radiator (passenger side) to the point where it attaches to the engine. Remove the two bolts at that location and you'll find your thermostat nestled in there.
Be sure to place a pail under the car to contain the coolant.
All the best
Ben
Trace the upper radiator hose to the mounting area on the intake manifold. Loosen the hose clamp on the manifold end of the hose and remove the hose. Pull the thermostat out of the intake manifold.
For more help and troubleshooting go through the help links below:---
Click the link below:-----
THERMOSTAT REMOVAL PROCEDURE/LOCATION DETAILS
Where is Thermostat Located on
Saturn
http://schematicsdiagram.blogspot.in/2012/06/2004-dodge-intrepid-how-to-replace.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-audi-a4.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-acura-car.html
http://repairhelpcenter.blogspot.com/2011/10/where-is-thermostat-located-on-2006.html
http://repairhelpcenter.blogspot.com/2011/10/thermostat-on-audi-19-tdi.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
How to Replace a Thermostat.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-thermostat.html
http://schematicsdiagram.blogspot.com/2011/12/how-to-locate-thermostat-on-any-car.html
http://technoanswers.blogspot.com/2011/12/where-is-thermostat-on-audi-a6.html
http://technoanswers.blogspot.com/2011/12/how-to-replace-thermostat-on-1992-buick.html
http://technoanswers.blogspot.com/2011/12/replacing-thermostat-on-1999-mercury.html
http://technoanswers.blogspot.com/2011/12/thermostat-replacement-on-toyota.html
