My creative Zen Z600 docking station will not switch on and work. The on off light keeps flashing blue and res. Red off blue on. The system does not work whilst this is happening. Tried turning it off and on short periods and long periods to no avail. This has happened before when the system is left on for long periods of time but at this time it is totally inoperable. Any ideas/tips?
Posted by robandlucy10 on
5 Related Answers
Anonymous
SOURCE: My Creative Zen M won't "dock"
My zen microphoto wouldn't dock after working well. It coincided with a download of windows media player 11. I was told to download media player 11 again and to restart the computer twice. Something to do with a driver missing. I didn't think this would work - but it did! In fact two zen micros that wouldn't dock are now docking perfectly!!
Posted on Apr 10, 2007
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Creative Zen Vision m
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Posted on Dec 17, 2007
TheGadgetDr
TheGadgetDoctor
  • 65 Answers
SOURCE: My Creative Zen Frozen in Docked Screen
If you tried to reset it, but it did not respond at all, this indicates that the reset button is broken. You'll need to have it repaired.
Posted on Aug 20, 2008
Anonymous
SOURCE: creative zen will not dock
Did you recently install another application to your computer? Like an anti-virus maybe? Try this. Go to Control Panel > Device Manager. Look for your Zen under Portable Devices. If you see an exclamation mark on your Zen, double click on it. Another dialog should pop up. Go to the Driver tab and click Uninstall. Then disconnect your Zen from your computer and reconnect it again. This solved the problem for me.
Posted on Feb 07, 2009
Anonymous
SOURCE: MY Creative zen V plus 4Gb will not switch on!!!
just throw it away......mine had a similar problem and i tried to disassemble it.....discovered it was refurbished despite the fact that i bought it from argos....
Posted on Mar 08, 2009
The pc froze whill i was uploading music onto my creative zen v plus and now the screen on the handset says docked and has the docked picture on it with flashing red lights either side. the handset is not...
Try holding the power button down for an extended period of time. If this does not work, there should be a small hole on the side of the device that will reset the player. You'll need to use a paper clip to press the button inside the hole, similar to ejecting a cd/dvd that is stuck in a computer. Hold the button down for several seconds to reset the device.
Feb 28, 2011 | Creative Labs ZEN V Plus MP3 Player
I have a Creative Zen V plus. It has worked fine
Try to switch it ON when it is connected with USB or charger. If it turns ON then batteries require replacement.
Jul 15, 2009 | Creative Labs Zen Micro MP3 Player
Creative zen won't turn on
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging.
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
Recharge Zen without computer
Use an usb charger or just go to creative store you can get the charger for your player
Some of the motoralla phones have the chargers identicall to ur players charger
ThankU
Dec 29, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen just flashes
have you tried to charge it using an ac charger?
May 19, 2008 | Creative Labs ZEN Vision:M Digital Media...
My creative zen touch will not dock
I had the same problem. This may help.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}http://support.creative.com/kb/ShowArticle.aspx?sid=16737
Apr 25, 2008 | Creative Labs Zen Touch MP3 Player
Frozen
reset button is next to data port. use paper clip,press hold.it should reset.
Feb 29, 2008 | Creative Labs ZEN Vision:M Digital Media...
Portable speakers
just specific ones for the zen player?
Dec 20, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Says it's not docked, but it it is
Is your hardrive ok chceck it by listening to it and if you hear a clicking sound then its stuffed. Try reinstalling the CD that came with it and then reload the firware it soud work.
Jun 15, 2006 | Creative Labs Zen Touch MP3 Player
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
