2005 Honda Accord Logo
Posted on May 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There's an annoying creaking sound coming from around my right rear wheel on my 2005 Accord. I think I've identified it as the trailer arm. Is that something I can replace myself?
mike mountain
Level 3:
President:
  • Master 1,916 Answers
  • Posted on May 23, 2011
mike mountain
Master
Level 3:
President:
Answers
1916
Questions
Helped
673053
Points
6183
They are usually fairly easy to replace, remove the large bolt that holds the arm to the knuckle, then remove the 2 bolts that hold the arm to the sub frame. Just grunt work really, not too hard.
1helpful
What is this creaking noise coming from the rear end of my chrysler crossfire?
sounds like worn rubber parts. Shoot some liquid lube on all the rubber parts focusing on where the rubber meets the steel part.
1helpful
2001 santa fe creaking noise when turning
1- front wheel bearing hub loose or loose axle nut
2- front shock(s)
3- ball joint(S)
4- lower control arm bushing(s)
all of these things can be checked by a professional in about 15 minutes and should be relatively painless financially
Honda Accord rear end rocks back and forth
Check back all parts to attach to wheel could be broken and body must be something broken or loose.
1helpful
When I back out of my driveway turning the steering wheel left, I hear a clunk or thud that seems to be coming from the right back area as I'm straightening out. I'm concerened that this may be a...
I would get a second opinion to compare physical inspection results. The wheel bearing is most urgent, as are control arm bushings.
Sound can transmit from one end of the car to the other, but the noise was heard in the rear and the balljoints are in the front.
The sway bar and its' bushings can make a noise. You will get body lean on turns with worn components, and some rear drive models have links which can break and detach.
You need to identify the Car Brand and model so the Experts know what you may have for components.
As you may have noticed, I have not said much about shocks. If you have shocks and not struts, there are different priorities. If either is leaking, the priority increases. Some strut towers have a bearing ring and when worn out, can be a safety issue. Shocks fit inside control arms and do not have a bearing ring. Rear suspensions vary, some use control arms on multilink types, others use a rear axle with springs.
But get the wheel bearing fixed. Have tierod ends checked. The guy under the car will have a better idea of its physical condition than what we can tell online.
T
2answers
Creaking 2001 isuzu rodeo
our first creaking ever.
love that.( its haunted? LOL)
nobody can fix a car, if you can't demo it
not heard, can't fix it if it is not broken, rings true here.
when you do that, they are forced to guess, at your expense.
its an Implied GUE$$
first off you need to find out when it happens. exactly
first. (bounce car hard parked)?
only turning, only at bumps, when?
only moving, I guess
it can creak and be AOK,
for example the front stabilizer bar is mounted in rubber mounts
and will creak. and be ok. (so spray them)
why not buy a can of SILICON spray ,and spray
all things under car that moves,
all things, not the drive shafts.
there are swing arms, Arms, and many things to make noises in the the whole suspension systems.
it could be tie rods failing (bad that)spray them.
if have weeks to find it spray 1 at a time>? tedious.
any suspension shop in town knows what to do.
find one.
a real shop can use his electronic 4 channel stethoscope
and drive it and find it. but must FAIL for HIM.
see?
2answers
I have a 2000 Honda Accord and as I accelerate over 45 mph the care starts making a progressively louder humming/buzzing sound. When I turn slightly to the right the noise will go away. Any ideas wh
sounds like the wheels are out of balance, is there a slight vibration through the steering wheel at this speed? and does the problem stop if you go faster (please drive carefully)
2answers
I have a bad vibration in my 2005 Honda Accord between 1500 & 2000 RPMs, usually between 38 to 48 MPH speeds. I do not think it is the wheels because I just had them rotated, and I am still having the...
If you are absolutely certain that the wheels are not needing balanced, then I would suspect the CV joints / Driveshafts. Sounds like one of them may be stuck.
2helpful
2answers
Creaking sound when turning wheel left
oil change and lube, should get that taken care of, and if not, they should be able to see if there is anything else to do, most cases anyways.. good luck, great little car!
1helpful
1994 Ford Taurus creaking left front
I think you are right. The strut or strut mount bearings on the top of the strut could be making noise. The shop might try and rip you off with additional repairs for the control arms,control arm bushings, or steering parts. I would take the vehicle to a reliable shop.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
