Question about Samsung Cameras
Samsung AQ100 camera seems to freeze after taking a few pics. It is only 4 months old & this has happened three times within a week ! I have had to take the battery out even though the last photo I have taken is still showing on the screen. I am very anxious about this given that I only have the camera a very short time !!
Posted by patriciagorm on
5 Related Answers
lukster
Luther Stephens
  • 217 Answers
SOURCE: Red Dots
You can get rid of the red dots by adjusting the V-scan voltage down, it's on the panel sticker inside the unit, you can find the test point on the DC to DC pcb, and the adjustment pot is on the same board, lower it as you watch the screen and only lower it enough to rid the screen of the dots
Posted on May 27, 2007
Anonymous
  • 3 Answers
SOURCE: black screen when in picture mode cant take pictures
PER007 in solution #3 is correct.
  • Follow the URL: http://www.nikonusa.com/email_images/nikonusa/service_advisory/launch_all.html
  • Fill out the form
  • Mail in your camera if it's listed
  • Receive your working unit free of charge
I had the same problem with my CoolPix5400 and this resolved the issue.
Posted on Dec 23, 2007
Parshiv Luthra
  • 395 Answers
SOURCE: my samsung digimax s500 camera still says card locked every time i go to take a pic.Someone kindly sugested holding the rest button, but i
THe SD card inside has a lever to its left Side .... Move it upwards ..... That is the lock on the Memory Card ...
Posted on Oct 16, 2008
Anonymous
  • 71 Answers
SOURCE: not enough free disk space message
Double check for the correct path to where you are saving the pictures. Maybe the software is trying to save to a CD-ROM or other drive.
Posted on Nov 25, 2008
Anonymous
SOURCE: my camera beeps three times
I figured out your problem because i was experiencing the same thing. The memory card has a tiny white switch on the side of it that says "lock". I'm guessing you accidently moved it like i did. I hope i helped you :)
Posted on Feb 10, 2009
Can someone help me on my nikon D3100 freeze problem?
New battery that is fully charged. My Nikon D3100 has had the problem of freezing every ten or so pics since it was a couple of months old. Still does it today after six months of use. I take a few hundred pics with it when shooting but only shoot once or maybe twice a month.
Have to take the battery out, put it back in etc. each time. Sometimes it allows me to power off and then back on but either way it's a pain in the rear and a serious "time waster".
Feb 12, 2012 | Nikon D3000 D3100 18-55mm
I HAVE A OLYMPUS CAMERA ONLY 4 MONTHS OLD AND I TAKE PICTURES GO BACK A FEW WEEKS LATER TO VIEW THEM ON THE CAMERA AND THEY'RE ALL GONE!!! WHAT'S GOING ON
review your manual in the "storing Pictures" section.
it might be something related to your card.
If it still acts up, you have a one year warranty under manufacturer. call Olympus.
Jul 01, 2010 | Olympus FE-280 Digital Camera
Slideshow freezes during slideshow
I wonder if ALL the pic's are correct Size & Format?
Feb 01, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Shuts off unexpectedly
Hi there.
Because the machine is only one month old i would recommend that you take advantage of the manufacturers warranty and send it in for repair, it won't cost you anything to do this as this sounds like a serious hardware problem or failure which is not of your doing.
Telling you to open the laptop will only void your warranty so this is not recommended.
Your computer will only be away for a week or so and i know it could be a pain not having it there, but for peace of mind this is the correct procedure.
Good luck and thanks for using FixYa!!
May 25, 2009 | Acer Aspire 3680 Laptop
Image problems - samsung L100
You can try a different memory card, but I don't think the problem is memory card, if pictures look scrambled, and colors and brightness are not uniform, that is either a problem with CCD sensor (optic sensor that takes the picture), or logic board.
In either case, this is not an easy repair.
Reset the camera to default settings from camera menu, and try a different memory card, but the camera will probably need to be sent in for repairs.
Jan 02, 2009 | Samsung L100 Digital Camera
Camera Samsung L77 won't stay on anymore
This is not an elegant solution, but it seems to be working. (I might have read some one else mentioning it for another brand of Samsung camera). I hit the end of the camera where the attachment to the computer gets plugged in against the palm of my hand pretty hard about 6 times. Then I tried it and it worked! There is some logic there since it started having the problem right after I put it down on a soft surface from about three feet.(Ididn't really drop it, but tossed it there - gently, I thought - because my hands were full and I was starting to lose everything). In the future I will treat the camera a little more gently knowing that mechanism is somewhat easily knocked out of adjustment.
Nov 03, 2008 | Samsung L77 Digital Camera
Power button problem
As you said, its 4 months old and assumed under warranty cover. Contact Sony Service Center for repair because if you try yourself, will void warranty.
Aug 15, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Samsung s630 digital camera
It was suggested that you remove the batteries and memory card for about ten minutes, then replace. It worked for mine, and works great now.
Mar 03, 2008 | Samsung Digimax S630 Digital Camera
Samsung rs2578sh
Yes, you have a faulty defrost heater or thermal fuse, the fault will re-occure within a few weeks. Regards Advisor
Aug 22, 2007 | Samsung RS2578BB Side by Side Refrigerator
Cameras Logo
61 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
