Weedeater Set (Weedeater) Logo
Rick Delserone Sr. Posted on Aug 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Weed eater starts and idles after it warms. When I accelerate it sounds like it is choking itself out or it is starved for gas then stalls.restart and it does it all over. Sometimes it stalls when i go to move it even before I try to accelerate. I think the carb needs an adjustment. This was brand new last year. I only used it once and had to run it in the half choke position.
richie46
Level 3:
Top Expert:
  • Weedeater Master 12,962 Answers
  • Posted on Aug 31, 2017
richie46
Weedeater Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946217
Points
58151
Take out carb and spray with carb cleaner through and into all portals. Blow out with air compressor.and reassemble.
Adjust idle and low and high mixture screws according for proper operation.
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Aug 25, 2009
SOURCE: ryobi weed eater ONLY RUNS WITH CHOKE ON HALF WAY
Check the carb jets, they might be a gummed up!
Anonymous
  • Posted on May 02, 2010
SOURCE: i have a ryobi weed eater clean carb change filter
I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
2strokeJim
2strokeJim
  • 577 Answers
  • Posted on Aug 01, 2011
SOURCE: starts but will not run
you are right, check your fuel filter, fresh gas and clean your carb out,also check your exhaust screen for being plugged, also a bad fuel cap could cause this, if the cap is not venting
Anonymous
  • 6468 Answers
  • Posted on Aug 12, 2012
SOURCE: WeedEater FL 1500
if the choke needs to stay on to run it then there is a plugged jet in the carb
Andrew White
  • 2239 Answers
  • Posted on Dec 15, 2012
SOURCE: weedeater FB25 5months old only used once and was hard to start right from the box. Can't get it to run now. What steps should I take on troubleshooting
This sounds much like poor car settings ( set too lean ) you need to richen up the L and H screw on the carb, unfortunatley there will be anti tamper sleeves on the carb or a special tool reqired to adjust them, turning the screws anti clockwise will richen the mixture if you manage to remove the caps or get hold of the apropriate tool.
2answers
Why won't my FeatherLite FL-20C weed eater will not stay running when I put it in full choke. What could be wrong?
It should run ok after warming up. After starting it, let it run for a minute or so and then try gradually opening the choke. You might try increasing the throttle setting at the same time. After the motor is hot, if you have to have the throttle setting increased in order to keep it running it means the idle setting needs to be increased, usually by turning a screw to keep the fuel valve from closing so much, or that there is a problem with the fuel flow......like a clogged jet or fuel passage in the carb.
Brand new and staling
Is the choke leaver in the off position when warmed up? Have you used correct fuel/oil mix?
16helpful
2answers
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
2answers
Weed Eater Problems
If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
May 17, 2010 • Troy Garden
2helpful
I have a Craftsman 32cc weed trimmer, can't give gas, it stalls
Usually the diaphram is wore out. It is a relatively inexpensive part. Does it run better with a little choke? If the answer is yes chances are it's the diaphram. Also sometimes the adjustment screws can move. There are two, one for low speed, and one for high. With the engine warmed up make small movements on the screws (some are marked low, and high) in, and out adjust til the engine runs at its optimum.
Hope this helps!
GBI 20 Weed Eater Blower ran out of gas and will not restart What to do to restart?
somewhere on it is a primer button pump it a few times and choke the blower it should start
1helpful
Poulan Pro weed eater won't accelerate.
check the fuel mixture screws on carb high should be turned in & 1 turn out & low side should be turned all the way in & 3/4 of a turn check those & let me know thanks wade
Top Weedeater Garden Experts
vince
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
